why we have boiler regs
fizzy | 29/10/2012 21:29:23 |
![]() 1860 forum posts 121 photos | Im no fan of the current restrictive blue book regs (as the comittee members are well aware) but having just looked carefully at the completed boiler in this link I have to conceed a little - the welds are hideous!! Looks like it was welded by a partially sighted first year apprentice!! Scary stuff.
http://discoverlivesteam.com/discoverforsale/forsale/1_bartlett/index.htm |
Steambuff | 29/10/2012 21:58:08 |
![]() 544 forum posts 8 photos | Thats why we have the 'Blue Book' ... To protect the innocent from the foolish !!!! By the way, I don't find the current regs restrictive .... but then I don't have any steel boilers, only copper. (3.5" and 16mm Gauge) Out of every 10 people that can build boilers, 9 can and they are quiet safe, but it is the other 1 that can't build a boiler but thinks he can, are why the reg's are there.
Edited By Steambuff on 29/10/2012 22:01:13 |
KWIL | 29/10/2012 22:20:15 |
3681 forum posts 70 photos | Note that the price in US$ . I do not know if the US has its own "bliue book" but litigation would sort it all out. |
fizzy | 29/10/2012 23:25:44 |
![]() 1860 forum posts 121 photos | blue book regs are great if your stuck in the 1940's...since then we have invented the mig welder and the tig welder...woohooo!
Steambuff | 30/10/2012 00:01:34 |
![]() 544 forum posts 8 photos | There is at least 1 company supplying Tig Welded Copper boilers, I am assuming that these meet the regulations. Sorry but I don't know about Mig/Tig Welding for Steel Boilers. (Not sure if the Blue Book specifies method of Welding -- My book is not to hand)
I am sure that when the Blue Book is revised, it will take account of the more modern welding technologies that are now available. Dave |
Ady1 | 30/10/2012 01:55:17 |
![]() 6137 forum posts 893 photos | What did they do with boiler tubes before welding was common? From 1850 to 1930 kinda thing |
Another JohnS | 30/10/2012 02:39:22 |
842 forum posts 56 photos | Ady; Expand them in place. Sometimes use a copper ferrule between tube and tube sheet to help seal. Welding really started with the Germans in WW2 from what I understand; stays were starting to be welded then, as it's a lot faster than tapping and threading and peaning the ends over. I used to do a fair amount with full sized stuff in North America; although I still hold my provincial license for "Steam Traction Operator" have not bothered to use it in a good few years now. I think rolling tubes is easier; when you take the tubes out, you of course have to use a torch to cut tubes just inside the sheets, then carefully remove the remainders. There always ("over here" practice, anyway) a king hole in the front tube sheet; all tubes come out of that hole, and can be "safe ended" and re-used, if ok. Safe ending is just welding on a bit more tube, maybe not worth it for the tubes, but the larger superheater flues it is/was usually done in "excursion" years. (IIRC, you can safe-end flues twice only) Google "49 cfr 230 steam" should bring up the US rules, Canadian rules are identical, except for the spelling (again, IIRC) Another JohnS
