Small Ba box spanners
Speedy Builder5 | 18/09/2012 19:34:13 |
2878 forum posts 248 photos | Following on from my enquiry about small head Hex bolts, I needed a 9Ba box spanner (Nut runner actually). Sorting through the come in handy metal stock box, I found a snapped off telescopic car ariel. One of the sections was about the right size to make a small box spanner. I took an old hex key and ground it such that it would enter the tube. I 'drifted' it into the tube to form the right size hex, then sawed the tube off to length. Cross drilled for a tommy bar and silver soldered it into place. Magic. Perhaps not the strongest, but suits my purpose. I suppose I could get the next sized section tube, slide it over the hex portion and silver solder into place etc.etc |
Ian S C | 19/09/2012 12:42:30 |
![]() 7468 forum posts 230 photos | What about a screw with a hex hole to fit that key you used, theres your nut runner. Ian S C |
Speedy Builder5 | 20/09/2012 12:43:15 |
2878 forum posts 248 photos | Yes, good idea if you can find one the right size. I forgot to mention that its probably best to find some stainless steel ariel - not the brass ones. |
Anthony Knights | 26/09/2012 22:46:53 |
681 forum posts 260 photos | If you have access to the digital archives, there are articles in issue 10 page 72 and issue 71 page 19 of MEW, on making BA spanners/nut runners. Edited By Anthony Knights on 26/09/2012 22:50:48 |
