Material
joey | 08/09/2012 21:36:54 |
![]() 31 forum posts | What grade or specification alluminium should I use to make pistons which run in cast iron sleeves. Alluminium to specification 6068 expands to much and the pistons seeze up. I allowed 0.05mm (2 thou) play, for a 40mm diameter sleeve/piston, between the sleeve and the piston. |
I.M. OUTAHERE | 11/09/2012 05:43:50 |
1468 forum posts 3 photos | Hi Joey. I had a look at one of my i/c engine books (miniature internal combustion engines by Malcolm Stride). And according to his reference you could use the following : Cast : LM51 Machined from barstock: HE 15 OR HE 30. For small compression engines (Diesel ) He recommends cast iron but no spec supplied . I imagine these designations change from one country to the next etc so you may need to search for an equivalent on the internet . There have been many articles in Model Engineer regarding engines so try there . Alternatively try the MODEL ENGINE NEWS website as they have masses of info on many types of engines . With a 40MM bore i would guess that you are using piston rings ? Are you sure that it is not them that is seizing in the bore (ring gap too small ) And if you are using rings try a little more piston to cylinder clearance say 3-4 thou . Are the pistons oval ? Should be smaller accross the wrist pin (gudgeon pin hole ) to allow for deflection or any flexing .
Ian
JasonB | 11/09/2012 07:42:16 |
![]() 25215 forum posts 3105 photos 1 articles | I've used HE30 (6082) on several IC engines but would be looking at more like 0.004" clearance. What sort of IC is it? slow reving hit & miss or higher reving 2/4 stroke? What rings are you using? J |
joey | 28/09/2012 21:22:02 |
![]() 31 forum posts | The engine is a 40% scale Anzani W 3 cylinder model of the engine which was used by Bleriot when he completed the first flight from Calais in France to Dover in England. I am using cast Iron piston ringss and the pistons have beem ground oval ( smaller across the gudgeon pin) by 0.05mm ( 2 thou) I will check out the the suggested remedies and report back at a later date. The engine is presumably slow revving with atimed exhaust valve and an atmospheric valve. In its current configuration it turns a 31 inch (diameter) X 12 inch (pitch) propeller at 2800 rpm, full throttle and Idles at 700 rpm. Thank you to everybody that posted replies so far, |
