Ian Parkin | 21/05/2012 19:51:11 |
![]() 1174 forum posts 303 photos | I have a startrite bandsaw most bearings are imperial sizes however the blade guide bearings are as follows marked nachi 10bcs 1nsl id 10mm (measured on the shaft it fits on) od 26.1mm ( measured on bearing) width 11.5 mm
any ideas as to a supplier? Ian |
robert ramage | 21/05/2012 20:03:42 |
6 forum posts | Since its only a blade guide bearing. Would it not be easier to use a bearing you can get off the shelf. 10 26 12. Simply bearings have this size in stock. |
V8Eng | 21/05/2012 20:05:09 |
1826 forum posts 1 photos | Possibly here. |
JasonB | 21/05/2012 20:07:14 |
![]() 25215 forum posts 3105 photos 1 articles | Have you tried one of the specialist Startrite spares dealers there are a few who do parts for old machines, whats the model?
J |
Jeff Dayman | 21/05/2012 21:13:06 |
2356 forum posts 47 photos | Hi Ian,
You can get the Nachi brg you mention from RPM Bearing in Boca Raton Florida USA or RPM Brazil. However they have $500 min order qty. - not what you wanted I'm sure. You can get a 63000-2RS1 standard bearing from any brg/industrial drives house in the world, many very inexpensively. This is the 10 x 26 x 12 brg Robert mentioned. I have bought similar sized bearings for less than a dollar each, if they are a stock standard size, at surplus and industrial drives houses here. JD
Ian Parkin | 22/05/2012 08:09:37 |
![]() 1174 forum posts 303 photos | Thanks for all your replies I know that a 63000 is close but I was more intrigued as to why startrite had used such an unusual bearing also these seem to be very expensive £6 for a budget and £12 for a brand name Ian |
