Member postings for robert ramage
Here is a list of all the postings robert ramage has made in our forums. Click on a thread name to jump to the thread.
Thread: Threaded Bar Rod Studding
01/06/2012 22:11:23
Hi Kevin. what sort of length are you after?
Thread: Engineer's Blue
24/05/2012 19:13:24
Hi clive were about do you live?
24/05/2012 19:13:14
Thread: can anyone find online supplier of this bearing
21/05/2012 20:03:42
Since its only a blade guide bearing. Would it not be easier to use a bearing you can get off the shelf. 10 26 12. Simply bearings have this size in stock.
Thread: nemett engine plans
07/05/2012 09:50:45
Looking for plans or copy of nemett engines.
Jaguar/bobcat and ne 15s engines. will pay for originals or copys.
Thanks in advance
Robby
Thread: syil vs tormach
02/06/2011 22:51:45
Im looking at buying a cnc machine. Any one got experience with eith the syil x6/x7 or a tormach 1100mill. ?
I work 95% of the time in aluminium,brass,and cast iron .
The other 5% is en19/en24 etc
what sort of cuts would i get in aluminium on the tormach using a 16mm cutter?
Any info much apprciated. Robby
