Aestus57 | 10/04/2012 14:12:20 |
![]() 30 forum posts 2 photos | Hi Folks,
As part of the horizontal mill engine I'm building, I've put together a built up crankshaft. Now, I've never used Loctite before so how do I degrease the parts and which number Loctite would you recommend. Thanks Peter PS the shafts are 5/16" Dia silver steel and the crank webs are 1/4" X 1/2" BDMS |
David Littlewood | 10/04/2012 14:21:41 |
533 forum posts | Hi Peter, For this application I would use Loctite 638 High Strength Retainer: It may be a confession of sloppiness on my part, but I've never found retainers are that fussy about degreasing; a quick wipe with acetone will do it. David Edited By David Littlewood on 10/04/2012 14:23:24 Edited By David Clark 1 on 10/04/2012 20:39:23 |
Ian S C | 10/04/2012 14:23:36 |
![]() 7468 forum posts 230 photos | Loctite 620 would be a good one, you can get a cleaning fluid, but I just use meths.It sets in 30 min, or 5 min if you use Primer 1, I use a similar one from another maker Lokeal, can't remember the number. Ian S C |
