Ian P | 08/04/2012 16:13:25 |
![]() 2747 forum posts 123 photos |
The leadscrew has a 12x1mm pitch thread and the point where it has broken is threaded M7x1 The plain parallel section is 9.80mm diameter and 20mm long. The 7mm dia ground portion is about 10mm long and fitted into the handwheel ballraces. I am not trying to get the leadscrew back exactly as it was but rather modify or adapt the bearings/housing and handwheel so that I can make use of the leadscrew and nut. My first thought is to machine an adapter that I can loctite on to the 9.8 dia part but I am concerned about keeping it absolutely concentric because the bronze nut is a very close fit (over 50 threads!). Is it possible to create threaded holes in very hard steel, say by spark eroding? Edited By Ian Phillips on 08/04/2012 16:14:07 |
Phil P | 08/04/2012 16:37:10 |
851 forum posts 206 photos | Yuur idea of loctiting an extension sounds OK, but I would leave it over size on its OD and machine it to size as a last operation. Loctite 601 is what I have used for years, and its never failed me yet. Phil |
Tony Pratt 1 | 08/04/2012 18:02:41 |
2319 forum posts 13 photos | I can't remember if you can create threaded holes in hardened steel by spark eroding but if you can it will be extremely expensive!! Your best bet would be to drill a hole in the leadscrew with a carbide drill, loctite a shaft in and finish machine said shaft in situ to ensure concentricity. Tony |
Ian P | 08/04/2012 19:42:30 |
![]() 2747 forum posts 123 photos | Michael Your method would be the ultimate way to go but a true, long, collet that grips on the threads would defeat me. As it happens the tops of the threads have been ground off (I thought it was an Acme thread at first) and the resultant OD is probably true to the axis of the screw. In theory at least, and with it being dead on 12mm diameter it should be possible to grip it in a high precision collet. Unfortunately I do not have anything to suit. If I could find some way to hold it accurately I could still use you method, but if I make an adapter with a stepped bore I would not need to reduce the diameter with carbide tooling. If the adapter does leaves some of the 9.8mm part exposed after being fitted I could use that with a finger type dial gauge and create a new centre in the 4 jaw chuck.
Ian There is a centre at the far end of the leadscrew and the 7mm diameter part is another original reference |
Les Jones 1 | 08/04/2012 20:07:00 |
2292 forum posts 159 photos | Hi Ian, If you mounted it with a centre and drive dog at the headstock end and fitted a ball bearing to the ground part near the break with the bearing held in the fixed steady you should be able to drill the end. If you then made an extension piece slightly over size and loctited it in you could finish machine it in position. You would need to apply pressure to the end with a live centre. The live centre would bear against the flat end of the extension piece or in a centre hole drilled after the extension was fitted. Les. |
Ian P | 08/04/2012 20:20:08 |
![]() 2747 forum posts 123 photos | Les What you describe is close to my original thoughts, the only problem is that the hole would have to be smaller than 7mm. Actually 6mm would be OK but will only leave a 0.5mm wall thickness, also I'm doubting whether it will drill as the steel is really very hard. I used to have some drills (bought after a demo at an exhibition) that are supposed to drill through files although they looked no different than normal masonry drills so thats what I eventually used them for. Ian
Les Jones 1 | 08/04/2012 20:55:33 |
I too have seen those drills advertised. (On one of the shopping channels.) I would not trust them to drill an accurate hole. The only further suggestion I can think of is mount the leadscrew in the lathe as I suggested. ( With a live centre againnst the broken end.) You could then skim the 9.8 mm (0.386" Les. |
Richard Parsons | 09/04/2012 05:01:36 |
![]() 645 forum posts 33 photos | Know any one who has an electric butt welder? If so try them you could get the two bits butt welded fairly accurately Rdgs Dick |
Ian P | 09/04/2012 11:34:43 |
![]() 2747 forum posts 123 photos | Richard 'Fairly accurately' would not be near enough for this part. I would imagine the manufacturers tolerance was measured in microns. I could imagine a very high instantaneous current from a stud welding machine joining on blank bit of steel which could then be machined up. |
Richard Parsons | 09/04/2012 12:41:27 |
The break seems to be in the part where the handle fits. The bearing looks as if it is on the main part of the shaft. If the bit of steel you had welded on then you will be able to machine it to size. The thing is it is a lead screw its major element for precision is that it has little or no back lash. If it is set up carefully a butt welder can position within the tolerance allowed by my Chinese inspector friend Wun Thou Wong. The butt welded area would need to be ground down. Rdgs Dick |
