Chris machin | 08/04/2012 10:55:13 |
59 forum posts | Hi All , looking thro the drawings before i order the materials for Elmers #24 beam engine , can anyone tell me how this eccentric part is made ? Any help appreciated Chris[ IMG]http://i5.photobucket.com/albums/y185/whitebeetle/beameccentric001.jpg[/IMG] |
Chris machin | 08/04/2012 10:58:16 |
59 forum posts | sorry , here;s the pic http://i5.photobucket.com/albums/y185/whitebeetle/beameccentric001.jpg |
Ady1 | 08/04/2012 10:58:56 |
![]() 6137 forum posts 893 photos | We had an interesting thread recently on making cams Milling or grinding seem to be the least stressful routes, will try to find
http://www.model-engineer.co.uk/forums/postings.asp?th=51412
http://www.model-engineer.co.uk/forums/postings.asp?th=64873
search for "crank" in main forum
http://www.model-engineer.co.uk/forums/searchresults.asp?Search=crank&SearchType=1&t=0
Edited By Ady1 on 08/04/2012 11:26:07 |
Tony Martyr | 08/04/2012 11:23:13 |
![]() 226 forum posts 45 photos | Chris, This is not a cam but rather a circular section with a hole reamed off-centre by a precise amount, therefore it can be fabricated from mild steel bar. I have just made 4 sets for my engine by holding the turned bar in a 3 jaw chuck centred and mounted on the milling table which is then traversed the (half throw) distance and locked. This allowed all 4 excentrics to be drilled and reamed at the same setting before being drilled a tapped for a locking grub-screw. Tony |
JasonB | 08/04/2012 11:23:19 |
![]() 25215 forum posts 3105 photos 1 articles | You don't really need to mill or grind the part. Just use a 4 jaw chuck Just use a length of bar long enough and lareg enough to fit the overall part in. Carefully mark the three centres on the faced off end and lightly dot punch. Next set up in the 4 jaw chuck and indicate the centre for the first eccentric, this can then be turned with a standard tool. Reset the work for the second eccentrics centre and use a parting type tool to machine that, finally set for the shaft centre and use the parting type tool again, then drill & ream before parting off. Its really all just off centre turning, been doing a bit myself over the weekend, this part had 4 different centres, all done using 4jaw chuck and a pic of it stationary
J |
Ady1 | 08/04/2012 11:27:44 |
![]() 6137 forum posts 893 photos | This is not a cam but rather a circular section with a hole reamed off-centre
Aye. Right enough. Got cams on the brain at the moment |
