Con Nicoll | 26/03/2012 23:40:23 |
3 forum posts | I am trying to positively identify the spindle nose thread form for my Murad Antarctica lathe. It's 1 3/8'' diameter x 10 tpi. I have tried Measuring the angle with both 55° and 60° thread cutting tools but without grinding the tip of the tool off it's difficult to judge the angle accurately. I first thought it to be 55° whitworth form however this does not seem to be a standard size. Can anyone advise? |
Russell Eberhardt | 27/03/2012 10:48:30 |
![]() 2785 forum posts 87 photos | But to put your mind at rest, Boxford threaded items, at 55 degrees angle, fitted perfectly well on my Atlas (US built) lathe spindle at the same size and pitch, but cut at 60 degrees. Mine too but I did give the thread on the backplate a light skim to make sure the chuck is located on the register and not the thread. Russell. |
Ady1 | 27/03/2012 10:55:31 |
![]() 6137 forum posts 893 photos | Cut an internal thread using a lump of Delrin or Aluminium and see how well it fits Using the 55 and the 60 tools
Only takes about 5 mins with a soft material
Had a quick look at one on lathes.co.uk and it just screams "atlas lathe!" Edited By Ady1 on 27/03/2012 11:04:33 |
Bazyle | 27/03/2012 12:53:07 |
![]() 6956 forum posts 229 photos | How about filing a bit of aluminium sheet to 55 and holding it against the thread. Although the wrong thread may fit it will be stressing the tips of the thread and may not ragiter correctly. |
S.D.L. | 27/03/2012 12:55:24 |
236 forum posts 37 photos |
Posted by Con Nicoll on 26/03/2012 23:40:23:
Hi several points
Steve Larner |
Con Nicoll | 31/03/2012 12:12:26 |
3 forum posts | Thanks to you all for the responses. After further careful measuring under a magnifying glass and a strong light it does seem to be a 55° thread form. I shall be machining a test thread on a piece of aluminium before I machine the face plate I have obtained for the lathe. |
Nick Easton | 06/06/2013 08:10:57 |
1 forum posts | Hi Con i was wondering if i could pick your brains about the lathe your using. I have recently bought one and could really do with some tips. cheers mate
Con Nicoll | 22/08/2013 13:02:52 |
3 forum posts | Hi Nick, I don't have manuals or anything like that and I'm not an expert, but I'll help if I can. Con. |
