Stub Mandrel | 22/03/2012 20:21:10 |
![]() 4318 forum posts 291 photos 1 articles | I've made a fair few involute gears using home made cutters. The world of cycloidal cutters seems very different - in John Wilding's series on the ME Jubilee Synchronome he advises the use of one cutter for gears from 16 to 0 teeth, including a crown wheel! How does one decide the best cutter to use for a given size of clock gear and number of teeth, and is it possible to make acceptable home made cutters in a similar way to those for involute gears? Neil |
John Haine | 23/03/2012 09:13:17 |
5563 forum posts 322 photos | There is a good book by j Malcolm wild, wheel & pinion cutting in horology, which describes all this. |
Russell Eberhardt | 23/03/2012 09:45:10 |
![]() 2785 forum posts 87 photos | Thorntons who make cutters for clock gears sell six different cutters for pinions from 6 to 16 leaves but just one wheel cutter for all sizes of wheel. Theoretically each wheel will need a different cutter but not in practice. I've not tried making my own cutters but the same principles apply as for involute gears. Some good advice is given here Russell. |
Stub Mandrel | 24/03/2012 21:20:19 |
![]() 4318 forum posts 291 photos 1 articles | Thanks,
That article doesn't make a whole lot of sense without any pictures though There isn't a lot out there on designing and making these cutters... Neil |
Bazyle | 24/03/2012 22:09:52 |
![]() 6956 forum posts 229 photos | The first hit on google seems pretty comprehensive http://www.csparks.com/watchmaking/CycloidalGears/index.jhtml Exactly how to design the tooth profile. Three cheers to Hugh Sparks for putting it out for the world to see. |
John Haine | 25/03/2012 13:57:02 |
5563 forum posts 322 photos | Read the article on Sparks' website on why cycloidal teeth are obsolete though. |
John Haine | 25/03/2012 13:57:03 |
Stub Mandrel | 26/03/2012 20:39:40 |
![]() 4318 forum posts 291 photos 1 articles | Thanks Bazyle - what did you google for? I looked for various things and didn't find that! And at the end of his pages he says "Sadly, I don't know of anything on-line about cycloidal gear design. If you make some gears, please make a web page and send me a note!" John - Surely not obselete for clocks? Neil |
John Haine | 26/03/2012 21:54:33 |
5563 forum posts 322 photos | Read the article! Written by a manufacturing engineer making clockwork fuses. |
John Haine | 27/03/2012 09:01:44 |
5563 forum posts 322 photos | The article I referred to is at http://www.csparks.com/watchmaking/CycloidalGears/RichardThoen.xhtml It is actually very hard if not impossible to make cycloidal gears exactly so they are always approximated by straight lines and circular arcs. I haven't seen any information on what errors this approximation introduces, I don't know if anything has been done. Involute gears however can be generated exactly using a hob. The article above suggests that actual production errors in cycloidal gears are quite large. The main reason usually given for using cycloidal gears in clocks is that they give lower friction in high-ratio step-up trains because their "action is before the line of centres". Thoen suggests that this is wrong, and that in practical production involute gears are (a) easier to make with smaller errors and (b) tolerate much larger errors (for example the wheels being too far apart) much better. I understand that one UK manufacturer of high grade clocks uses involute gearing. Of course, nowadays it doesn't really matter! |
Stub Mandrel | 27/03/2012 21:19:54 |
![]() 4318 forum posts 291 photos 1 articles | This is interesting. I have read in several places that the errors introduced by using circular form tools to make involute cutters are less than the manufacturing tolerances for the cutters and far less than the errors at each end of a tooth size range. Given that the main problem that seems to haunt all amateur clockmakers is depthing the wheels, going involute seems to be a no-brainer (as I'm not seeking either a gold medal or fellowship of the FBHI) Neil |
Buster | 28/03/2012 08:51:11 |
20 forum posts | Hi Neil, if you join my clockmaking group on yahoo you will see in the files section jigs for making your own wheel/pinion cutters http://groups.yahoo.com/group/Clockmaking/, also the davewestclocks web site has many of my published articles on clock repair/making, regards David |
Russell Eberhardt | 28/03/2012 15:45:22 |
Posted by Buster on 28/03/2012 08:51:11:
Hi Neil, if you join my clockmaking group on yahoo you will see in the files section jigs for making your own wheel/pinion cutters http://groups.yahoo.com/group/Clockmaking/, also the davewestclocks web site has many of my published articles on clock repair/making, regards David I can't see a file there on cutter making. Is it still there. What's it called. Or am I just going blind in my old age. Many other useful files though. Russell. |
johnp10 | 28/03/2012 21:20:57 |
25 forum posts 4 photos | Hello Gents. A friend has acquired a Synchronome master clock and some slave clocks which he would to make into `stand alone` clocks. Does anyone know of a suitable battery powered circuit which will provide the nessary 30 second impulses? |
Stub Mandrel | 28/03/2012 21:52:25 |
![]() 4318 forum posts 291 photos 1 articles | Hello John, A 32 KHz crytsal oscillator divided by 960,000 using a few logic chips than a buffer to make the pulse the right size would work, or a micro buff would use a microcontroller to do the job all in one chip, a crystal, and a few capacitors.
A simple test circuit to prove the idea could be based on a 555 ic http://www.farnell.com/datasheets/80468.pdf don't expect a high level of accuracy, evin if it is called a 'precision' timer Neil Edited By Stub Mandrel on 28/03/2012 22:01:32 |
johnp10 | 01/04/2012 16:04:49 |
25 forum posts 4 photos | Thank you Stub mandrel. I have passed on your information. |
