Stub Mandrel | 04/03/2012 21:20:43 |
![]() 4318 forum posts 291 photos 1 articles | I've just tried silverflow 55 - it's different to easyflo! It takes more heat to remelt it. If it has only just melted you get more of a fillet, but this is hrd to control. I used it to do this little tank for the shunter (about 1 1/8" high, from 0.7mm brass. First time I've tried something like this - it left several joint lines visible as when I attached the base a the solder in the curved joints seemed to run out. A bit of hi-build primer should sort it out though. Neil |
Terryd | 04/03/2012 22:03:14 |
![]() 1946 forum posts 179 photos | Hi Neil,
You could caulk the joints with soft solder as a filler. Takes well to silver solder as if has an affinity for silver, just don't let it contaminate your work area if you intend to make silver jewellery Terry |
Mark Foster 1 | 04/03/2012 22:54:32 |
34 forum posts | I have also found the cad free stuff just Junk !!! some improvment with LACO flux but not a patch on the old cad stuff .I use it most days its my trade .still have a couple of kg of the old stuff .I worries me about the boilers being built with this ! |
Stub Mandrel | 05/03/2012 21:11:33 |
![]() 4318 forum posts 291 photos 1 articles | I've done so more experimenting - the extended melting range really notices - it flows like water when it is hot enough, but not before. Also noticed how puny my blowtorch is compared to even the smallest nozzle on my propane torach - there's no hot 'cone' with the blowtorch - it looks like the legendary paraffin blowlamp bushy flame, but isn't very hot. Neil |
