Recessed grinding wheel
David Clark 102/02/2012 09:33:18
3357 forum posts
112 photos
10 articles
Hi There
I would like to get a recessed grinding wheel.
6inch diameter x 1inch or wider thick.
Does anyone have any suggestions where I can get one at reasonable cost?
regards David
Edited By David Clark 1 on 02/02/2012 09:33:42
The Merry Miller02/02/2012 11:49:51
484 forum posts
97 photos
David, Peter Child do various recessed wheels.
It also depends whether you are just after a recess for getting the mounting flange under flush to enable the clamping nut full engagement or are you looking for what is known as a cup wheel?
Len. P.
David Clark 102/02/2012 12:04:36
3357 forum posts
112 photos
10 articles
Hi Merry Miller
I want one for side grinding on.
The recessed feature means the wheel is wider at the outside diameter then the middle so there is more on the side to wear.
Peter Childs is out of stock and also does not specify the grit.
regards David
John McNamara02/02/2012 12:09:16
1377 forum posts
133 photos
Hi David
I found a couple:
The Search I used. Note the use of the + that forces google to only return only sites that contain that word or phrase if it is in quotes +"nnnnnnn" .
But this search is better removed 6 inch:
The Tool Post:
There are others.
Cheers
john jennings 102/02/2012 12:24:49
69 forum posts
David
AXMINSTER POWER TOOLS list a 150x40 white alumina 80 grit as a spare for one of their grinders. From catalogue photos there is about 25 mm or so of flat rim. About £14
Bad news currently out of stock
Best wishes
David Clark 102/02/2012 12:45:09
3357 forum posts
112 photos
10 articles
Hi John
Seen that one.
Might be ok.
Will pop down to Axminster on Saturday if weather fine.
Only about 20 miles and they have the entire grinder in stock.
I really wanted about 46 or 60 grit but 80 will do.
regards David
Michael Cox 102/02/2012 12:52:46
555 forum posts
27 photos
Hi David,
Have a look at
I have used them twice and the service and range are second to none and the prices are also very good.
Richard Parsons02/02/2012 13:51:03
645 forum posts
33 photos
David have a look at Arc Euro Trade (Usual Disclaimer) I have seen their advert somewhere. I bought one of their dianond wheels and it grinds well
Rdgs
Dick
Edited By Richard Parsons on 02/02/2012 13:51:53
Les Jones 102/02/2012 15:53:04
2292 forum posts
159 photos
Hi David,
I think this is the company suggested by Michael Cox selling on Ebay.
This may be a suitable wheel for you. Cup wheel It does not say what grit the wheel is but you could ask them if it is suitable in other respects. I bought two cup wheels from them about two years ago and have had no problems with them.
Les.
David Clark 104/02/2012 15:38:42
3357 forum posts
112 photos
10 articles
Hi There
I got a 60 grit recessed wheel from Axminster.This should do.
regards David
