Tapers
Wolfie24/12/2011 13:34:10
502 forum posts
OK next round of silly questions
I want to make some tommy bars for a couple of things. Now as it stands they appear to be tapered so they don't fall out again.
Now how do I go about that? I know you can make a taper with a taper reamer but to what diameter do you drill the pilot hole, presumably the smaller diameter?
And how do I taper the bar, in one case its quite small. Doing it in my lathe seems like a bit of overkill.
David Littlewood24/12/2011 13:39:52
533 forum posts
You can get taper pins up to a quite respectable size, and these are made with the same taper as the taper pin reamers (though be aware that the taper is slightly different for metric and imperial ones). I used taper pins in this way to make handles on my pillartool and VDH - no way was I going to spend half a lifetime making ball handles for the thing!
David
JasonB24/12/2011 16:22:33
You can also just use a good fitting drilled or reamed hole and knurl the centre section of your chosen bar, this increases the dia slightly making it a tight fit in the hole.
j
Stub Mandrel27/12/2011 15:53:46
4318 forum posts
291 photos
For non-critical things, like a clamp for the drilling table, a centre punch will raise enough of a bump to stop a tommy bar falling trough a well fitting hole.
