What is 20/40 DP?
GoCreate | 24/12/2011 04:53:41 |
![]() 387 forum posts 119 photos | Hi
I was looking at gear hobs on ebay.
This one is described as 20/40 DP,
I know what 20 DP is and what 40DP is.
How can it be both 20/40 DP? Can anyone explain this description?
Cheers
Nigel |
GoCreate | 24/12/2011 06:05:41 |
![]() 387 forum posts 119 photos | Spoke to soon
I found the answer here
It's not an involute gear hob but it is an involute spline hob. The spline is 20DP but has a shallow depth equivalent to 40DP.
So no good for cutting gears I presume.
Nigel. |
John Stevenson | 24/12/2011 17:32:44 |
![]() 5068 forum posts 3 photos | No, as you say they are for splines. I have bought quite a few hobs off this guy, don't be put off by the life left in the pics, he tends to use the same picture and all the ones I have had have had far more life in them. He does have other hobs but usually metric. I think ARC still has some imperial hobs left John S. |
Richard Parsons | 27/12/2011 08:35:41 |
![]() 645 forum posts 33 photos | Does anyone know where to find the ‘wire’ sizes for making involute cutters and hobs? rdgs Dick |
Rufus Roughcut | 27/12/2011 10:46:33 |
83 forum posts 20 photos | Hi Dick
Try Hear which may be of use |
John Stevenson | 27/12/2011 12:19:26 |
![]() 5068 forum posts 3 photos | Dick, As far as I know there are no published tables but worked out by the makers of the hobs. The tables in the linked page above are for gears and not hobs. Hobs will be different in that they have to take clearance into account. John S. |
