Why do small taps have a pointed end?
Glyn Davies10/11/2011 20:56:43
146 forum posts
56 photos
Hi there. Does anyone know why small taps have a pointed end? Is it just to centre the tap during its manufacture and is there any reason not to grind the point off to allow the tap to cut a little deeper when tapping blind holes?
Thanks
Peter G. Shaw10/11/2011 21:04:17
1531 forum posts
44 photos
I have done this on an occasional plug tap.
As I understand it, the pointy bit allows for re-sharpening, so if it is removed, then resharpening can't be done, however my limited experience is that I break more taps than I wear out so it does not matter.
I am not an engineer, so my understanding may be complete rubbish!
Peter G. Shaw
Stub Mandrel10/11/2011 21:12:58
4318 forum posts
291 photos
Yes its for sharpening. Larger taps have a centre in them for the same purpose. I grind it off, at least from the plug (bottoming) tap.
Stewart Hart10/11/2011 21:41:00
674 forum posts
357 photos
Its a male centre for grinding, if they used a female centre on a small tap, the little hole would weaken the end of the tap. In the tool room I served my apprenticeship in it was standard practice to use male centers for grinding small tools and gauges, it meant that you had to run in between female centers, a full one at the head stop end of the grinder and a 1/2 centre at the tailstock end.
Stew
