Trevor Wells | 07/09/2011 21:52:52 |
8 forum posts 3 photos | Hi I would appreciate some help with a problem with my clark 300m lathe, When I started to turn a piece of metal this evening at quite a low speed a rumbling sound came from the chuck area and the chuck almost stalled setting the lathe at a very slow speed I was able to hold the stock bar in the chuck and stop the chuck moving but there was still a rattling noise coming from the headstock as if a gear or belt was slipping.. Before I have to strip the headstock I was wondering if anyone had any ideas what this might be. Thanks in anticipation. Trevor. |
Pat Bravery | 07/09/2011 22:37:01 |
![]() 96 forum posts 24 photos | I have had the same, in my case the belt stripped it's teeth, I changed the sprocket and belt, fairly easy job. Best regards Pat |
Trevor Wells | 07/09/2011 22:50:03 |
8 forum posts 3 photos | Thanks for that Pat ,Was that on a clark lathe too ? |
Pat Bravery | 07/09/2011 22:55:56 |
![]() 96 forum posts 24 photos | Yes the CL300, I get spares from Clarke or Machinemart and find them reasonable, best regards Pat |
Trevor Wells | 07/09/2011 22:58:21 |
8 forum posts 3 photos | Thanks a lot |
Trevor Wells | 08/09/2011 21:45:07 |
8 forum posts 3 photos | Checked the lathe tonight and thankfully it was just a loose drive belt, Re-tensioned and now working fine.. |
Stub Mandrel | 15/09/2011 22:32:06 |
![]() 4318 forum posts 291 photos 1 articles | It's worth taking the time to check the belt isn't rubbing, there are various screws that adjust the angle of the motor as well as the tension. A related problem I had was the plastic key in the middle of the toothed pulley stripped. I hand filed a groove to replace it and fitted a metal key. Neil |
Trevor Wells | 15/09/2011 23:18:28 |
8 forum posts 3 photos | I did check to make sure it wasnt rubbing but the motor does seem to be angled downward at the pulley end . |
