The Merry Miller | 15/06/2011 14:42:26 |
![]() 484 forum posts 97 photos | Yipee, I've just taken delivery of a Tom Senior M1 with both horizontal and vertical features included. The vertical head is the S-type with its own drive motor. Steve Cox of Landylift collected it from Preston and brought it down to Essex this morning. Can't recommend Steve highly enough.. Now I'm even a more merrier miller., let's get machining. |
David Clark 1 | 15/06/2011 15:06:12 |
![]() 3357 forum posts 112 photos 10 articles | Hi There
Can you give me a list of the head speeds, the S type.
I have a light vertical with the S type head but no speed chart.
regards David
The Merry Miller | 15/06/2011 15:21:45 |
![]() 484 forum posts 97 photos | It's from about 1962 David but I will try to sort it. I might have to calculate the speeds. The head is attached to the over-arm so you can pull the head away from the main body to give greater reach for the cutters. |
David Clark 1 | 15/06/2011 15:35:11 |
Mine is similar I think except it does not have the horizontal spindle.
The head is on a round bar with and index on a large diameter disk but I think you could pull it out a few inches.
Only thing is you would lose alignment.
Any chance of a photo?
regards David |
The Merry Miller | 15/06/2011 16:12:18 |
![]() 484 forum posts 97 photos | I don't know if this helps David. Len. P. |
NJH | 15/06/2011 16:42:06 |
![]() 2314 forum posts 139 photos | Hey Len Wot - no swarf yet! ![]() I had use of one of these for a while - nice machine. Hope you have many happy hours together. regards Norman |
The Merry Miller | 15/06/2011 16:51:56 |
![]() 484 forum posts 97 photos | David, some more info. The head is a stepped four pulley arrangement with poly-vee belt drive. I notice from an early manual they were three speed pulleys giving 750, 1450, and 2800 rpm using a conventional "A" section vee belt |
The Merry Miller | 15/06/2011 17:17:32 |
![]() 484 forum posts 97 photos | Tom Walshaw in the ME from June 17 1977 gives a run down of the V head. He says the 4-step pulley gives speeds of 500, 970, 1660 and 2800 rpm. He doesn't say what speed motor for those speeds but goes on to say that with a lower speed motor you will get 340, 600, 1000 and 1600 rpm. |
David Clark 1 | 15/06/2011 21:27:35 |
I must have the low speed motor.
Must go and get a bicycle computer at the weekend and find out for sure.
regards David
The Merry Miller | 16/06/2011 12:48:37 |
![]() 484 forum posts 97 photos | David, the manual I have got for my TS lists oils that are no longer in existance today. Do you have info on oils that can be used with your TS? Len P. |
David Clark 1 | 16/06/2011 15:10:31 |
I just use the Myford ones.
regards David Edited By David Clark 1 on 16/06/2011 15:55:24 |
