never seen anything like it
Reamer
Speedy Builder512/06/2011 20:45:42
2878 forum posts
248 photos
Just picked up some new French metric (I guess the same as UK metric - just French made !) reamers from a car boot sale. I have never seen reamers like it, but was assured that they will cut accurate holes in steel, brass etc.
A third of the circumference have no cutting flutes, and the other two thirds have normal flutes. Anyone used / seen these before ?
Speedy Builder515/06/2011 18:56:42
2878 forum posts
248 photos
344 other people never seen anything like it - surely some one knows.
Andrew Johnston15/06/2011 19:18:06
7061 forum posts
719 photos
Since there are no pictures, technically you're the only person who has seen it!
Roderick Jenkins15/06/2011 19:58:40
2376 forum posts
800 photos
Robert,
Taper reamers for making the holes for musical instrument pegs have only 3 flutes on half the circumference, the rest being plain. If you try to cut a hole in a soft material like wood using a conventional reamer the reamer tends to pivot around the cutting edges in turn and you end up with a facetted hole. I guess a similar thing can happen in soft metals, it certainly can happen in sheet material. I would expect your reamers to be very accurate, if a little slow cutting. Spiral flute reamers are now available for musical instrument which helps to eliminate the problem but they still have a least one flute missing (or at least that's how it is on my lute peg reamer).
Rod
dcosta15/06/2011 20:43:09
496 forum posts
207 photos
Hello Robert!
When I started my intereste in engineering, in the beginning of the eighties, I saw reamers like that many times in professional shops. At that time I heard they being called something like “backed reamer”. In its name (that in portuguese is descriptive of the reamer, not just a name), the third of the circumference without cutting flutes is the “backed” part of the reamer. I think they were of common use here in Portugal.
I've used one or two and, yes, they work very well.
Only now I thought about how that reamer work. I think that the function of the “backed” part is to crush small bosses left by the normal flutes and also to (kind of) polish the surface.
I only recently re-started my interest in engineering and in the meatime I think I lost them. Tried to find them with no luck.
Best regards
Dias Costa
Chris Trice15/06/2011 22:26:09
1376 forum posts
10 photos
Bit of a cross between a reamer and a D-Bit maybe.
Nobby15/06/2011 22:38:23
587 forum posts
113 photos
Hi
If the reamed hole is a bit small .On the 1/3 plain section you can add say .001 shim etc.& ream by hand.Having said that I havent seen them
Nobby
JohnF17/06/2011 00:04:31
1243 forum posts
202 photos
Hi Robert,
Yes I have used this type of reamer some 40 years ago in industry, they often came with carbide inserts in the plain portion to prevent wear--always with a carbide cutting tip as well. They are a little slow cutting and you really need to flood with coolant or oil and run relatively slow.
They cut a very straight hole and yes they operate similar to a D bit but cut faster and more efficiently. If memory is good they were designed by PERA [production engineers research organization] They never caught on with the major tool makers and I have seen few since--still have a couple somewhere I think!
Regards John
