Eric Cox | 09/03/2011 09:38:18 |
![]() 557 forum posts 38 photos | i intend to silver solder small components copper, brass,steel (EN1A) using a butane torch. Which silver solder and flux do I need. |
Michael Cox 1 | 09/03/2011 10:32:35 |
555 forum posts 27 photos | Hi Eric,
I would use Easyflo 2 and Easyflo flux.
Mike |
mgj | 09/03/2011 13:16:10 |
1017 forum posts 14 photos | Apparently Easy Flo (as a trademark) has been stopped by Johnson Matthey. So it is a case of while stocks last, if you have a particular brand loyalty to EF. Otherwise the same alloy remains available. CUP alloys would be a good source . I bet Thessco are still doing it too. The trade name will be slightly different, thats all. There are non cadmium bearing alloys wih the same properties if you want to go that route. If you go to CUP alloys website it will all be explained in detail. |
KWIL | 09/03/2011 15:35:30 |
3681 forum posts 70 photos | There is no doubt in my mind that the non cadmium versions do not "flow" so nicely. I agree with mgj, CuP Alloys is a good source. I use their 842 range as a multi purpose alloy Edited By KWIL on 09/03/2011 15:35:49 |
