Mandrel Handles
Nobby12/01/2011 16:33:42
587 forum posts
113 photos
I
Does anybody find these mandrel handels  usefull ? .  They are a great addition to any ones lathe . Mine is sprung Loaded for safety. Usefull when dieing down threads(not title threads) in use I always switch the m/c off . When cutting fine metric threads with M/C switched off i can lock  the handle .i close half nut take a cut buy winding handle bring tool  out leave half nut closed wind back take another cut . Feedback welcome
Regards Nobby
KWIL12/01/2011 17:01:22
3681 forum posts
70 photos
With an Inverter drive, I reduce the speed to very slow and do the same but under power, with the S7 clutch I find I can judge the stop point very well. If you do not have an inverter, the handle is a good way of doing it, if a little tedious.
macmarch12/01/2011 17:12:03
147 forum posts
Nobby, This is how I do my threading on spacers on my BH600.  I only have 1 thread for the undercut and often 2 threads for the job.  With female threads it would a braver man than I am. Even with inverter drive there is only 20 thou to play with.  I can't rely on the drive to stop in 1/2 a turn.
In my version the handle fits into slots around the circumference.  Down the centre there is an adjustable rod which I can use as a backstop.
If anyone is interested I'll put up pics in Hints and tips.
Ray
macmarch12/01/2011 17:12:06
147 forum posts
Ray
macmarch12/01/2011 17:13:16
147 forum posts
Oops clicked to quick.
Nobby13/01/2011 10:57:44
587 forum posts
113 photos
Hi Ray
 Thank you for feedback on this  item Look forward to pics in Hints and tips.
Regards Nobby
wheeltapper13/01/2011 11:35:08
424 forum posts
98 photos
Hi Nobby
this is the handle I made for my Chester Comet.
my lowest speed is 100 rpm so short threads are a no no under power.
It's an expanding mandrel type.
as you can see I have to open the gear cover to fit it so turning the power off is a must.
Roy
Edited By wheeltapper on 13/01/2011 11:36:30
Nobby15/01/2011 11:38:31
587 forum posts
113 photos
Hi Wheeltaper
I like your lores table stop . Heres my adjustable stop on my S7 Mk 1can be stopped in 2 postitions using collars on 5/16" stop bar .Note rule for seting
