daniel962 | 31/12/2010 14:38:13 |
9 forum posts | Hello everyone, I'm new and I introduce myself, my name is Daniel I live in Pesaro, Italy. Now I expose my problem, given the difficulties in sending me a lathe MYFORD at reasonable cost, I decided to buy it in pieces on ebay. The pieces that I have received are for a MYFORD super 7mk1 serial number SK 7343 and miss many details, some of you know where I can find everything before Edited By Katy Purvis on 01/06/2015 11:54:25 |
wotsit | 31/12/2010 15:52:20 |
188 forum posts 1 photos | Hi, Daniel,
Its an odd way to buy a lathe, but good luck - a good start would be to use Google and search for Myford Super 7. The Myford site (www.myford.com) has a parts number and price list for the later Super 7, so you can get an idea what the new price for a part is (If you can identify it) - but there are many other sites with information.
http://www.lathes.co.uk/myford/page2.html also has a great deal of information for these lathes.
Good Luck - Keith
Edited By Katy Purvis on 01/06/2015 11:53:58 |
daniel962 | 31/12/2010 17:26:26 |
9 forum posts | Hi Keith,unfortunately for shipping quotes made me very expensive, so I have a super MYFORD 7 to the market price, with 210 pounds of shipping costs but I miss the parts mentioned above. Regards Daniele |
Chris Trice | 31/12/2010 17:31:07 |
![]() 1376 forum posts 10 photos | Er... you don't mention which parts you are after. |
daniel962 | 02/01/2011 16:00:55 |
9 forum posts | Dear Chris, after a check of all the original parts, wear and restoration of tolerances, and careful reassembly, I have a functional MYFORD super 7 mk1. But at the time after the misbehavior of a seller, I miss the twin vee pulley for mk1 and adjustment screw for lubrication of the spindle. Edited By daniel962 on 02/01/2011 16:03:25 |
Nobby | 25/01/2011 22:39:22 |
![]() 587 forum posts 113 photos | Hi
If you want can let you know the dims. and thread on the lube screw on the Super 7 MK1
Regards Nobby |
daniel962 | 26/01/2011 12:26:38 |
9 forum posts | Hi Nobby, you do me a great pleasure. Regards Daniel |
Nobby | 26/01/2011 16:17:53 |
![]() 587 forum posts 113 photos | Hi Daniel
I hope this helps and you can see the dimentions The length from under head is 2&3/16" ( 55.5 m.m) to intersection of 20 degree inclusive angle . the thread is !/4 BSF x 3/4 (19m.m ) long M6 may screw in?
the knurrled head is 5/8 Diameter (16mm ) The head to suit your requirments domed or flat etc We may get some feeback on this from other members
The material is Mild Steel Regards Nobby Edited By nobby on 26/01/2011 16:22:33 |
daniel962 | 26/01/2011 19:12:21 |
9 forum posts | Hi Nobby Thank you very much, you were a great help for me, your design is well made, thanks again. Regards Daniel |
daniel962 | 27/01/2011 12:22:59 |
9 forum posts | Dear Nobby, a my own curiosity, the lube screw is required to open and close, or adjust the oil supply? Regards Daniele |
Nobby | 27/01/2011 16:35:04 |
You can adjust the oil drips, And you can see through the site glass to see the oil dripping. By screwing it right down it shuts the supply off .
Regards Nobby |
Richard Edmonds | 12/04/2011 19:09:12 |
13 forum posts | Hi I am new here but have seen a couple of small single phase myford lathes for sale on ebay. What are the serious pitfalls to buying an older machine as opposed to a brand new cheapo from China. I was looking at something for around £600.00 what can I expect for this amount |
JohnF | 12/04/2011 23:43:21 |
![]() 1243 forum posts 202 photos | Hi Daniel & Richard, you both might like to look at this link to the Myford guide to buying a used lathe, there are quite a few good tips on what to look for.
Richard, if you can I would buy a used Myford or Western made machine against a far east product every time BUT you need to make sure it is in good condition wear wise---particularly on the bed and saddle. Expensive to recondition!
Have to say though the far eastern products have improved greatly in the last few years and do represend good value for money. I did read an article in one of the mags a few months ago regarding accuracy to be expected and if it was my Myford I would be bitterly disapointed with the performance--if you are capable a Myford will work to 0.0005" limit and its been in daily use for over 30 years.
Richard Edmonds | 13/04/2011 20:06:11 |
13 forum posts | Thanks John that is something to keep in mind. Everybody seems to know Myfords so although I have a chinese machine now, I am leaning towards replacing it with something trusty. As well as that I like the old British motors that power them even I can change bearings etc on them |
Robbo | 13/04/2011 21:12:55 |
1504 forum posts 142 photos | Hi John,
Thanks for that link, useful even for old codgers like me. I haven't looked at the Myford site for a while, it is certainly improving.
I suggested to Richard that he try Tony Griffiths site, lathes.co.uk, for a buying guide, link
http://www.lathes.co.uk/page2.html takes you to it.
Phil |
Desmond Farthing | 14/09/2011 15:53:49 |
6 forum posts | Hello all, my name is Des. I have a Super 7, one of the early models with the horizontally le operated lever clutch and the cast in headstock lubricator with sight glass, prior to the wick feed.
I foolishly engaged the drive with the chuck key in place, resulting in it striking the bed, which fortunately was undamaged but now the cone pulley rotates without driving the spindle.
Before I attempt to dismantle the headstock I would appreciate advice from anyone cares to give it. My first thoughts were that a drive/woodruff key had broken. I believe a "half round spanner" is needed, dimensions would be appreciated
Hopefully
Des
Nobby | 14/09/2011 18:53:42 |
![]() 587 forum posts 113 photos | Hi Where you switch over to use the back gear that may have sheared off. ? Regards Nobby |
Clive Hartland | 14/09/2011 19:40:17 |
![]() 2929 forum posts 41 photos | I am wondering if the Hex. locking bolt has just jumped out of engagement to the shaft?
It has happened to me on my Myford ML10.
You need a cut short allen key to fit the Hex. head bolt that is in the side of the pulley and loosen it and lift it up to engage the lock, then tighten afterwards.
Clive |
Nobby | 14/09/2011 23:34:59 |
![]() 587 forum posts 113 photos | Hi Guys
If you take the spindle out you will find there is a wooruff key there as Desmond said it my be that one has sheared . You will need a C /1/2 round . when replaced it will give you a chance to set the that front tapered bronze bearing as per myford instructions.
Nobby
ady | 14/09/2011 23:45:04 |
612 forum posts 50 photos | I was looking at something for around £600.00 what can I expect for this amount --------------------- You will get a phenomenal Myford Drummond Mseries for this. The REAL cost is the tooling so you can "do stuff" Don't aim too high to start with, get a functional unit...and then learn. In the chicken and egg situations of life it's worth starting at the easiest fastest cheapest end of the issue. Then you will know how far you want to take things once you get some experience. ...and what you can do with it.... if you make the effort |
