Mick "h" | 29/11/2010 12:04:14 |
5 forum posts | I have a A&S Horizontal Milling M/C Model "0A"-can anyone tell me the type of taper in the horizontal mandrel is please, As a Vertical head is too expensive for me I'm wondering if I can fit a mandrel of the correct taper to which I can fix collets etc to use an end mill in This would be run from a 2nd motor to give the higher speeds required.Its the same sort of set up as milling in the lathe with end mill in a chuck. I think my m/c was made in the 1940's & only cost me £30 so has to be saved!!
Mick |
NJH | 29/11/2010 13:37:17 |
![]() 2314 forum posts 139 photos | Hi Mick
Tony shows an "0" model on his site here;- www.lathes.co.uk/adcock&shipleyhorizontal/page2.html
The text gives 30 INT as the taper - so there's a start for you!
Norman
Edited By Katy Purvis on 01/06/2015 11:48:28 |
David Clark 1 | 29/11/2010 14:00:54 |
![]() 3357 forum posts 112 photos 10 articles | Hi Mick
Should be easy to fit a self-contained vertical head where the overarm is.
Perhaps a Unimat lathe or similar small milling head.
regards david
Mick "h" | 30/11/2010 11:58:52 |
5 forum posts | Thanks Gents--The lathes website is really good & I have found a 30 int arbour that takes 2 morse taper tooling from RDG Tools so I'm going to try that,hadn't thought of a self contained vert head & will see whats available before I spend money
Regards Mick |
Kenneth Lindeman | 23/12/2011 04:42:04 |
![]() 37 forum posts 5 photos | Hi All I am looking for a manual for the Adcock & Shipley mill |
Brian Dickinson | 23/12/2011 06:42:48 |
![]() 62 forum posts 13 photos | Try the above link, this guy has a load of stuff.
Happy Christmas
