Simple indicator needed
Gordon W | 05/11/2010 11:28:27 |
2011 forum posts | This may be off-topic, but I know there are lots of electrical/ electronic experts out there. I have a water pump 100m from house,350W motor, fed from house via fused spur and underground cable, this cable is live at all times. The pump is controlled by pressure switch on the pump and cuts in when pressure drops. I am trying to devise a simple cheap indicator in the house, preferably a lamp, to show when the pump is running ie. current is flowing in the wires. A return cable is a non-starter (u/ground) Also have compressor with the same requirement. Can anybody help? |
modeng2000 | 05/11/2010 11:46:39 |
340 forum posts 1 photos | The electricity energy consumption meters have a current clamp that goes round either the live or neutral wires and indicate the load in watts. John |
john swift 1 | 05/11/2010 11:53:12 |
![]() 318 forum posts 183 photos | try pluging the pump into a energy saving extension lead / adaptor
with the pump pluged into the master socket
and an indicator lamp in one of the slave sockets
you will have on of the shelf solution with no electrical or electronic knowlge required
In the past maplin sold a velleman kit that did what you want
but I expect you want the ready to go solution
John |
Les Jones 1 | 05/11/2010 12:44:24 |
2292 forum posts 159 photos | Hi Gordon, If an LED indicator w
ould be bright enough you could try this circuit. It would be connected in series with either the live or neutral feed to the pump at the house end. The diodes need to be able to withstand the starting current of the motor. They only need to be a low voltage rating as they do not have the mains voltage across them. You could also use a 3 volt torch bulb (Without the series resistor.) If you did this then replacing the lower diode with a string of four would make it brighter. Les.
John Haine | 05/11/2010 13:29:43 |
5563 forum posts 322 photos | Les, an elegant solution, but shouldn't the LED be shown the other way round? |
Gordon W | 05/11/2010 14:55:38 |
2011 forum posts | Thanks for all the very quick replies.I don't mind making something up, I'm not totally useless, but what do I start looking for? The diodes/LED looks good, starting load I guess will be at least 3 amp (against 30m head).Energy saving extension lead, new to me but sound ok. The Maplin kit also ok, I will look into all these, now I know what I'm looking for. I was loaned a clamp type ammeter, but only showed briefly on start-up, guess the load on run was too low. |
Les Jones 1 | 05/11/2010 15:21:02 |
2292 forum posts 159 photos | Hi John and gordon, John, you are correct. I have drawn the LED the wrong way round. One other thing I did not mention is that the circuit as it is will not work with a white or blue LED as the requre about 3 volts. Gordon, I would go for 10 amp diodes as the starting current on some types of motor can be very much more than the running current. The energy saving extension lead has one socket that the main load is plugged into. The other sockets are only powered up when the main load draws current. (For example a computer as the main load and monitor and printer plugged into the other sockets.) If you used this method you would plug the pump into the main socket and say a table lamp into one of the others. There are also plug in energy monitors that diplay current or power. Les. |
Gordon W | 05/11/2010 17:46:19 |
2011 forum posts | Thanks again, just had a quick look on ebay, loads of diodes, remarkably cheap, but so far can only find up to 2amps. Can diodes be run in parallel? Will look into all ideas over weekend. |
Les Jones 1 | 05/11/2010 22:18:36 |
2292 forum posts 159 photos | Hi Gordon, Although there are no suitable diodes on Ebay there is someone selling 35 amp bridge rectifiers for £1.45 Here is a modified design that can be built with two bridge rectifiers. |
Gordon W | 06/11/2010 09:56:15 |
2011 forum posts | Thanks Les ,thats ideal, I think, must get back into this electronics stuff, never done much since transisters were invented, and the price was 7/6d. Still don't understand how the energy saver extension leads saves energy tho'. I would go that way if I can find a cheap one with less than 5 sockets. Thanks all. |
john swift 1 | 06/11/2010 10:43:55 |
![]() 318 forum posts 183 photos | hi Gorden
just for information
Poundstretcher sell a 4 way adapter with 2 slave outlets for about £10 (I had a look yesterday)
the velleman kit K8034 is more expensive ! and you still need a box to put it in !!
going for the diy solution
to save a component and make construction easy
you could use a two lead bi colour led (eg maplin QY83E) to replace the led and D1
in les jones circuit
Nicholas Farr | 06/11/2010 10:48:48 |
![]() 3988 forum posts 1799 photos | Hi Gordon, no I don;t understand how energy saver extension leads save enegy. Probaly just purer copper, so has a few micro omhs less resistance, which of course costs more to buy.
Regards Nick. |
Les Jones 1 | 06/11/2010 13:01:05 |
2292 forum posts 159 photos | Hi Gordon, I think this is the item that John mentioned. Les. |
john swift 1 | 06/11/2010 14:28:27 |
![]() 318 forum posts 183 photos | Hi
Les, thats the one
Gordon and Nick
for some time I've used an eight way adaptor with my pc
switching off the pc also switches off the printer ,hub , external
hard drives and monitor
like it used to do with the older pc with a real on off switch and a mains outlet
any saving is due to the automatic power switching to ancillary devices
a lot off electrical devices never switch off but go into standby
think of all the set top boxes in use because analogue tv has beem switched off for example
Edited By john swift 1 on 06/11/2010 14:30:32 Edited By john swift 1 on 06/11/2010 14:51:38 |
Les Jones 1 | 06/11/2010 14:58:55 |
2292 forum posts 159 photos | Hi Gordon and John, I have just re read the original post. The 100 meter run of cable will have a significant capacitance causing some current to flow even when the pump is not running. This will probably be enough to light the LED dimly so a resistor will probably be required between the ends of the string of diodes. (I would suggest about 27 ohm as a starting point.) It may be better to use a 3 volt torch bulb instead of the LED, diode and resistor. Les. |
Stub Mandrel | 06/11/2010 20:25:03 |
![]() 4318 forum posts 291 photos 1 articles | Les, that's a really neat solution. Congrats! Neil |
Gordon W | 29/11/2010 17:38:43 |
2011 forum posts | Just a report, have built device to Les's diagram, using 2 rectifiers, after looking at drg. properly . works well, for info. V with no load 1V. with pump running 3.8V, when I can find my car will go buy a bulb or two. |
