dixie | 14/08/2010 18:57:34 |
31 forum posts | Hello. Are 4jaw s/c chucks any better with normal circular material than three jaw s/c chucks. I can see the advantage for turning a round on something perfectly square or drilling through the centre of a square, but are there enough advantages to justify the cost. I ask this question because someone said get your self a four jaw s/c, but could not say why when pressed. |
Bogstandard | 14/08/2010 19:39:00 |
263 forum posts | I use my 4 jaw self centring most of the time, except when using hex bar. I have found over the years, all my 4 jaw sc chucks have slightly less runout than my standard 3 jaws. usually less than 0.002". I find them just a little more versatile for my personal needs as I tend to use round and square stock more than round and hex. For a first chuck, I would definitely go for a three jaw, then a four jaw a very close second. Just as a point of interest, no matter which chuck you buy, get a set of soft jaws to fit at the same time. I won't buy a chuck unless soft jaws are available for it, and if used correctly, soft jaws can make precision machining a piece of cake. Bogs |
NJH | 14/08/2010 20:13:42 |
![]() 2314 forum posts 139 photos | I guess that a 4-jaw s/c will hold round stock a bit more firmly than a 3- jaw and it's very useful for holding square stock. It won't however hold hexagon stock which is, perhaps, a more common requirement ( well for me anyway). I managed with a 3-jaw s/c and a 4-jaw independant for many years but recently treated myself to the 4-jaw s/c. Nice but if I could only have one I would go for the 3-jaw. Norman |
Stub Mandrel | 14/08/2010 20:46:01 |
![]() 4318 forum posts 291 photos 1 articles | In theory a three-jaw chuck will hold stock firmly with all three jaws, but unless it (and the material) is perfect a four-jaw chuck will only give full contact on three of the four jaws. Just as a three-legged stool will stand without wobbling on a flagstone floor, but you can spend hours ages making a four-legged table wobble free on a flat floor! In practice I'd guess there is enough give in any decent chuck to mean this isn't an issue (i.e. you can always nip the jaws up a bit after they make contact). I reckon a badly worn 3-jaw will still grip the work (though it may run out badly) but a badly worn 4-jaw will probably allow the work to wobble. Neil |
dixie | 17/08/2010 20:00:53 |
31 forum posts | Hi Many thanks to all those who gave an opinion to my query, I dont think I need to get one just yet.. Thanks Again Brian. |
