A bi-metallic balance wheel
This adds to my posting about John Steven's Skeleton clock with lever escapement
Sam Stones26/07/2010 08:44:15
922 forum posts
332 photos
As was suggested some weeks ago, I’ve added a couple of photographs to my CLOCK album. The first shows the bi-metallic balance wheel in its cage and the second was taken a little closer.
For an impression of size, the graduations are millimetres, the balance-wheel arbor is 1/16" dia., while the ten timing screws are threaded 10BA. The heads of some of these screws may have to be hollowed out from the threaded end, should they be found to be too heavy during the regulating process. This hollowing out leaves a shell to create the impression that all the screws are of equal weight.
At this close range it is clear that having stood for more than 25 years, more cleaning and polishing is necessary. To the right of the wheel can be seen tiny dots which are blow holes in the brass. I tried five times before I succeeded in minimising the size of these holes, and can’t imagine repeating the process without a proper workshop.
Although not particularly clear, the wheel is split in two places so that the bi-metallic action can take place.
I haven’t reached the point of making the spring as yet, but my first attempts will use a 0.008" steel guitar string, this happens to be the size I determined using Moment of Inertia calculations. I’m presuming at this stage that the spring properties will suffice rather than go to the expense of the preferred metal, Invar I believe.
The drilled holes through the spring stud and the spring collet at 0.8mm dia. are just visible ready to take the ends of the spring. The steel collet has been split for adjustment purposes.
Below the balance wheel is the roller and impulse pin which engage with the lever as part of the escapement. While they are virtually complete, the detail of this latter mechanism must wait until I’ve built one or two more parts.
The bearings for the balance wheel and the lever arbors are from 1/8" dia. silver steel and have been heat treated to be pot-hard.
That’s about all I can tell you at this stage, but I welcome any questions.
Stub Mandrel26/07/2010 20:30:05
4318 forum posts
291 photos
Ah!!
Now I understand your origina description. A picture is truly worth a thousand words!
I look forward to seeing more.
Sam Stones10/01/2011 05:07:40
922 forum posts
332 photos
I had been wondering to what degree the bimetallic balance wheel would change its shape due to temperature.
Stripping the wheel down to its bare minimum, I first soaked it in boiling water, then took a photograph. This was repeated but using the fridge freezer to again soak the wheel.
Because of the small bulk of the wheel, and thus a fairly rapid return to room temperature, I estimate that there would be about a 60 degree C temperature differential between the `warm’ and the `cold’ conditions.
Also, please refer to my album "John Stevens Skeleton Clock" with the (much) greater number of pictures.
I wonder if this was worth the trouble.
Sam
A CAD image of the wheel.
The wheel at two temperatures.
The change of shape is very slight. Will this be enough?
Cornish Jack10/01/2011 11:50:47
1228 forum posts
172 photos
Sam
No sort of expert on this, but would the RELEVANT dimension change be the diametrical distance change between circumferential weights? If the whole balance wheel is expanding/contracting I would have thought the gap change would be minimal.
Rgds
Bill
Billy Mills10/01/2011 13:23:44
377 forum posts
The whole wheel does not expand much at all, the two  C's change in curvature so that the three screws move further or closer to the axle because of the bimetalic construction. The only test of the correction is to measure the rate at different temps, i.e. to look at all of the parts of the system working as intended.
The spring material properties are the other major part of the rate tempco, changing the spring material may require moving the screws.
Alan.
