_Paul_ | 10/07/2010 21:01:26 |
![]() 543 forum posts 31 photos | Can anyone help I finally got around to changing the bits of tatty channel currently supporting the ML7 to the proper Myford raising blocks, 1st problem was no studs with the blocks then I didn't have any 5/16 x 22 tpi studding. So having made 18" of studding and some nuts to suit I can't find the dimensions for them does anyone know what length the studs should be? Regards Paul |
NJH | 10/07/2010 21:25:25 |
![]() 2314 forum posts 139 photos | Hi Paul If no one here can give you an answer I suggest you give Myford a call. Despite some anti Myford sentiment from some on this forum I find their customer service second to none. They take endless and patient care to answer any query helpfully - even some of the footlin' things I have given them! I certainly wouldn't swop my Myford . Regards Norman |
mick | 11/07/2010 17:43:27 |
421 forum posts 49 photos | Hi. Paul. Tap them out to M8 its vertuialy the same pitch, you'll only take out a smigin of swarf. M8 studding is far easier to source, any builders merchant stocks it for fencing, then simply cut to length, thats the way I did mine, with no problems. |
_Paul_ | 11/07/2010 17:59:07 |
![]() 543 forum posts 31 photos | Hi Mick What length did you make them Regards Paul |
KWIL | 11/07/2010 19:24:09 |
3681 forum posts 70 photos | As I recall the standard length was 5" for a metal base Myford Stand but you could get longer 7.5" ones as well for use on a thicker bench top. |
