Nick Clarke 1 | 08/03/2010 14:41:50 |
20 forum posts 6 photos |
Has anyone come across a machine like this before? (see photo) It has 3 crompton motors, 1 to drive the grinding head, 1 to drive the workhead and 1 to drive the lapping plate. The workhead on my example has 2 pratt burnard 5 inch scroll chucks mounted on it and swivrls on a mounting that is graduated in degrees. This assembly can bev moved longitudally along the bed via a leadscrew. the grinding head has 2 wheels (one on each end) and moves across the bed. It also has a coolant system supplied by a gearwheel type pump.
The machine is of 1970's vintage and is in perfect condition. I have a notion to convert it to another use, any ideas? the photos are scanned from the manual, I will post better ones when I get my camera fixed.
Edited By Katy Purvis on 01/06/2015 09:45:05 |
Circlip | 08/03/2010 15:10:21 |
1723 forum posts | Set up refurbing fuel injectors Nick, the price they charge for a "Replacement injector" makes it viable in these recessionary times. Last saw one used 45 years ago when we used to REPAIR things.
Regards Ian. |
Nick Clarke 1 | 08/03/2010 15:20:40 |
20 forum posts 6 photos | Many thanks, however,I wouldn't have a clue how to start, instruction manual a bit vague in places. |
Keith Long | 08/03/2010 15:53:00 |
883 forum posts 11 photos | With the various drives and motions available to you I'd have thought you could have sharpened or made just about any cutters on it and given them a mirror finish to precise size on the lapping plate. Should also be able to do cylindrical grinding probably small scale surface grinding as well. |
Nick Clarke 1 | 08/03/2010 16:00:42 |
20 forum posts 6 photos | Thanks for your suggestions, I shall have a go, as a relative newcomer to this hobby I will need to do some research into tool and cutter making |
Nick Clarke 1 | 08/03/2010 16:00:55 |
Nick Clarke 1 | 08/03/2010 16:01:27 |
David Clark 1 | 08/03/2010 18:29:05 |
![]() 3357 forum posts 112 photos 10 articles | test |
David Clark 1 | 08/03/2010 18:29:33 |
Nick Clarke 1 | 08/03/2010 19:07:52 |
20 forum posts 6 photos | How do you remove posts? I dont know how 3 copys got there, althrough there was an error message at the time of posting |
Nick Clarke 1 | 08/03/2010 19:09:03 |
20 forum posts 6 photos | How do you remove posts? I dont know how 3 copys got there, althrough there was an error message at the time of posting. Just got the same error message. |
