drive belt
malcolm evans | 05/11/2009 21:09:01 |
5 forum posts | Hi all, anybody any experience of the flat drive belt fitted to the Keneddy hacksaw? the one fitted is starting to look a bit tatty and I would like to get hold of a replacement before it breaks !! it appears to be fabric on the outer and a kind of nylon/plastic on the inner surface, it must be oil proof with all the crud it gets on it and it hasn`t gone soggy like a rubber might do, any ideas for a replacement?? thanks, MALC. |
mgj | 05/11/2009 22:33:52 |
1017 forum posts 14 photos | You could try the link at the top of the page? www.v-belt.eu They seem to produce lots of belts with no minimum order. |
Gep Engler | 22/01/2010 22:26:00 |
23 forum posts 3 photos | Dear all,
I am also a happy owner of such a small Kennedy power hacksaw.
![]() But my machine has a V-belt.
See picture on my homepage: http://home.kpn.nl/gep2/Sub-pagina's/Machines.htm
(klick on picture for larger photo.)
And elsewhere on the Web, I found another specimen that uses a toothed (timer?) belt. See: http://www.lathes.co.uk/advertphoto/090822kennedy/
That page also contains, unfortunately bad quality, copies of a brochure plus the first page of the (maintenance) instructions. So probably, there has been a manual.
Unfortunately, I do not have any maintenance/operating instructions.
![]() Although the operation and maintenance are straight forward, it would be nice to have my machine "complete".
Therefore my question:
Does anybody have the complete operating/maintenance instructions and can provide a scan? Thanks in advance !
![]() ![]() Furthermore, I added an automatic switch-off to my machine. Very convenient!
As this is at the back of the machine; you can not see it on the picture.
But, if anybody is interested, I can add an extra picture.
Best regards from The Netherlands,
Gep
e-mail: gep2<at>hetnet.nl
home page: http://home.kpn.nl/gep2/
Gep Engler | 22/01/2010 22:26:12 |
Gep
Chris B | 08/02/2010 08:32:47 |
34 forum posts 5 photos | I got a replacement flat belt made up by Tony Griffiths at Lathes.co.uk |
Clive Foster | 08/02/2010 12:39:25 |
3630 forum posts 128 photos | An effective alternative to old school flat bets is the multi-groove "serpentine" V-belts used for car engine accessory drives et al run Vee side down.
Following advice from USA I used one on my Heavy 10 lathe with excellent results although the necessary split and lace up procedure was a pain. For the Kennedy you only need to find one of a suitable length.
Clive |
Ian S C | 09/02/2010 10:12:27 |
![]() 7468 forum posts 230 photos | It is possible to obtain heat joinable flat belting in a wide range of widths and thicknesses.Old poly V belts or toothed timing belts win hands down for price,what you get for free is always the winner. Ian S C |
Richard Parsons | 21/11/2010 14:36:39 |
![]() 645 forum posts 33 photos |
Yes the saw in MEWS was a form of Kennedy saw. It used a Klaxon Motor with it’s built in gear box as a direct drive to the pitman. The rest of the thing was also made up of Hex and square barbar. As the blade was a standard 12” hand saw blade it would be easy to scale up from the photo. It needed no belts |
