ian weeks | 26/08/2009 09:00:09 |
33 forum posts | dear All, I seem to remember reading an article on using Lazer pointers to align milling machine heads I have found the one in mew no79 but this is not the one I remember as it uses a lazer from maplin whilst I seem to remember one using a cheap hand held pointer and modifying the hole -is my memory playing tricks thanks Ian |
keithmart | 26/08/2009 09:10:41 |
![]() 165 forum posts | Hi
Often you can buy a laser level from a pound shop. This attached to the side of the mill column and aligned to a mark on the ceiling provides an accurate aligning point for the mill head.
As a by product it shows the stability of the mill when running |
Ian S C | 26/08/2009 15:11:09 |
![]() 7468 forum posts 230 photos | There was a bit in ME a few years ago,i shoul try one myself as they are only about NZ$2 here,less than £1,can't remember the date of the artical but I think it was post 2000.The one in ME fitted in the chuck and used for centering.IAN S.C. |
ian weeks | 28/08/2009 08:04:38 |
33 forum posts | Thanks for the information -this all came about when I was tidting the work shop and found a laser pointer I had started to modify and neverr finished -always the case- will now try and finish the job-ian |
