Robert Hodgkins | 22/07/2009 07:39:24 |
5 forum posts | Hi
I've just purchased a GLANZE 6MM BORING TOOL and Its the first time i have used an indexable tipped tool. This bar is round in cross section and has two flats on it, which I thought was to make sure it is held in the toolpost to give the correct cutting angle. When mounted the the tip insert is angled downwards at about 15 degrees. This is totaly alien to my understanding of the correct rake angle.
Am I mounting this wrongly?
On my Myford the Quick change tool post holder for boring has a Vee in it. Is this bar made to sit in that? My Quick change tool holder on my Cowells lathe has no Vee so it would be very difficult to set the tool at anything other angle.
I have looked at the Glanze web site and this really has no help. I would appreciate any help.
Thanks
Bob |
David Clark 1 | 22/07/2009 09:29:31 |
![]() 3357 forum posts 112 photos 10 articles | Hi There
Use as is on the flats.
Should be fine.
regards David |
Graham Horne | 24/07/2009 16:08:39 |
14 forum posts | Hello Bob, while looking into inserts for some heavier than usual cutting I found this website which answered many questions about flip-flop inserts and negative/no rake .
http://www.metalwebnews.com/howto/toolholder/toolholder.html May help you. Graham |
