Here is a list of all the postings Robert Hodgkins has made in our forums. Click on a thread name to jump to the thread.
Thread: Burnishing |
26/11/2020 13:45:03 |
Hi Guys Thanks for that. I'll check out the Clicksprings on you tube. Thankfully I have only machined one end of the arbor at the moment. There is only a very minimal amount of play on the main wheel. I have not started attacking the frame arbor holes yet. Regards Bob |
26/11/2020 10:10:32 |
Hi Guys I am just finishing the main wheel and barrel of my JW 8day clock. I did turn the barrel arbor down to 5/16" on the ratchet end as per the drawing. I have reamed the hole in the main wheel to 5/16" as described by JW. The problem I have now is after burnishing the arbor its .003" undersize. Should I have allowed for this when turning and made it oversize? I have read on the forum that we engineers make things tight, am I worring too much or will I have to remake it? Thanks Bob |
Thread: Pivot Steel |
06/11/2020 23:14:52 |
Hi Guys Ok I am working to the "How to make A Weight Driven 8-day Wall Clock (updated)" book from Ian Cobb. I have made the Frames, Pillars and Barrel. I have just plunged into cutting the ratchet teeth. I really should hve read the script before posting. Sadly I just looked at the diagram and just saw 3/32" and assumed I needed that size blue pivot steel. I have now read in a bit more detail and I can whats required. I was just trying to put a materials order together for what was coming up. I am currently working on the main wheel but have run into a snag. I made a Aluminium arbor which I turned up on my Cowells Lathe. I stuck the blank to it with super glue and turned it all to size drilled and reamed 5/16". I have to cut my gears on my Warbeco milling machine. I have a divisionmaster with a 4 jaw centering chuck. When I transferred the arbor to the mill I loose concentricty. Its only a few thou but I'm not sure what my tolerences are as I have never made gears before. I think I am going to buy a 14mm rotary table adapter so I can just move my cowells 3 jaw with the Ally arbor in it to see if it improves things. The black art of clock making Lol. But I am enjoying the challenge atm. Bob |
06/11/2020 19:20:01 |
Hi Guys I'm pretty new to clock building. I have just started building JW Eight Day Wall clock. I'm not really ready to make the pivots yet but i was making an order for materials and I thought I would order some blue pivot steel. JW's book says 3/32" but I see that is not readily available now. What size should I go for 2.5mm? Thanks Bob |
Thread: Insert tip Boring bar |
22/07/2009 07:39:24 |
Hi
I've just purchased a GLANZE 6MM BORING TOOL and Its the first time i have used an indexable tipped tool. This bar is round in cross section and has two flats on it, which I thought was to make sure it is held in the toolpost to give the correct cutting angle. When mounted the the tip insert is angled downwards at about 15 degrees. This is totaly alien to my understanding of the correct rake angle.
Am I mounting this wrongly?
On my Myford the Quick change tool post holder for boring has a Vee in it. Is this bar made to sit in that? My Quick change tool holder on my Cowells lathe has no Vee so it would be very difficult to set the tool at anything other angle.
I have looked at the Glanze web site and this really has no help. I would appreciate any help.
Thanks
Bob |
