cutting copper
16 gauge
david simmo12/06/2009 08:22:11
33 forum posts
 hi as you can see Iam new to model engineering,I would like to buy some tools for cutting copper 16 gauge ,and would like advice on the best tools for the job in hand the manufacturer all say there is best . in the past I asked
 the me forum and got so good answer thanks dave ps having truble  wih pc
 hope to get it fix today
JasonB12/06/2009 16:50:57
If its simply cutting to size then a fine toothed hacksaw say 32tpi will do. It can help to sandwich the plate between scraps of ply or MDF to reduce the risk of teh blade catching.
To finish the edge then a decent sharp second cut file will do
What are you making as it will give a better idea of what type of cutting is required.
Jason
John Wood113/06/2009 15:14:22
116 forum posts
I use a device called a 'Goscut' Basically it comprises a handle/frame with a flat metal rail at the top (horizontal) which has a slot along its length, a blade fits within this slot and the flat material is placed on the top rail and is cut with the blade which hinges from below. Because the rail has two sides the metal is kept flat. I can't remember the make, was it Eclipse? but I don't think they are available now. I still pick up the odd one at car boot sales.  Back a bit was the 'Nibbler' tool which was popular and widely advertised in ME but I don't think they are available either. Someone must produce something these days, I just thought a couple of names might give you a lead though.
Circlip13/06/2009 15:45:13
1723 forum posts
"Monadex" John??  In the same vien "Hens Teeth" nowadays.
      Regards  Ian.
