Inverted slide valves
John Billard 103/10/2023 19:53:30
111 forum posts
Does anyone have any experience of putting a spring below an inverted slide valve to ensure its contact with the valve face?
Best wishes
John B
Andrew Johnston03/10/2023 21:28:27
7061 forum posts
719 photos
Not directly, but I have designed the LP valve on my compound traction engine so that it uses a simple flat leaf spring to keep the valve in contact with the valve face. The design is based on the full size valve.
Edited By Andrew Johnston on 03/10/2023 21:31:19
John Billard 103/10/2023 22:04:10
111 forum posts
Thanks Andrew. That's interesting.
How is the spring attached?
John B
Paul Lousick03/10/2023 22:15:01
2276 forum posts
801 photos
Similar to Andrew, The slide valve on my Ruston TE has a slide valve on the side which kept falling off and not sealing when steam was shut off. Then bang back on when turned on.
A simple flat leaf string attached to the back of the slide valve (made from "Band-it" steel strapping) and rubs against the back of the cover plate fixed the problem. Very little force is required to hold the valve, just enough to keep it seated.
Edited By Paul Lousick on 03/10/2023 22:19:05
Redsetter03/10/2023 22:16:49
239 forum posts
My only experience of this was with a 5" Pansy with valves below the cylinders. On starting, there was a short delay after opening the regulator until the steam chest pressure increased enough to lift the valves up, and you could usually hear a click when this happened. You could induce this by snapping the regulator open, then backing it off to the starting position. It really wasn't a problem once you knew about it.
