Dalboy | 19/09/2023 19:26:48 |
![]() 1009 forum posts 305 photos | I have a set of UNF taps and dies but the problem is there are no bottoming taps and the size that I need I only have one so do not want to shorten it to make a bottoming tap other wise I will not have one that is a starter tap Looking around for a 3/16" bottoming tap I keep coming up with either none available but they show a 10-32 which is 0.002" larger than the 3/16" is this compatible.
JasonB | 19/09/2023 19:34:50 |
![]() 25215 forum posts 3105 photos 1 articles | Below 1/4" UNF and UNC use a number system rather than the nominal diameter so yes #10-32 UNF is their nearest to 3/16" dia and you can happily thread 3/16" rod to that size. If you happen to have 2BA that will also do for 3/16"
Edited By JasonB on 19/09/2023 19:37:17 |
Chris Pearson 1 | 19/09/2023 20:23:15 |
189 forum posts 3 photos | Posted by JasonB on 19/09/2023 19:34:50:
Below 1/4" UNF and UNC use a number system rather than the nominal diameter so yes #10-32 UNF is their nearest to 3/16" dia and you can happily thread 3/16" rod to that size. If you happen to have 2BA that will also do for 3/16" Ignoring the angle! |
Brian G | 19/09/2023 20:59:33 |
912 forum posts 40 photos | I freely admit to getting very confused with threads, but looking at Tracy Tools website wondered whether 3/16 x 32 UNS would do the job? Brian G |
Dalboy | 19/09/2023 20:59:42 |
![]() 1009 forum posts 305 photos | Posted by JasonB on 19/09/2023 19:34:50:
Edited By JasonB on 19/09/2023 19:37:17 Thank you Jason I am so use to using the imperial sizes when going down below 1/4" but that was many moons ago, and have only come across the numbering system like the 10-32tpi system with the modeling side of things. |
Andrew Johnston | 19/09/2023 21:24:50 |
![]() 7061 forum posts 719 photos | Drill Service have a 10-32UNF bottoming tap for £4.60p, plus VAT of course. Andrew |
Dalboy | 19/09/2023 21:47:02 |
![]() 1009 forum posts 305 photos | Thank you guys but have now found some 3/16"UNF ordered. The main thing was that I have made some parts using my one I have as well as making some male threads, but this one part has a shallow hole which needs to be threaded right to the bottom. With all the taps and die sets and loose ones that I own there are still some that I need |
