Margaret Trelawny | 15/09/2023 14:37:16 |
100 forum posts 42 photos |
Sorry. Hello everyone- can you advise me how to remove the locking pin from the cross slide carriage please? See photo. I feel like giving it a huge whack woth a giant hammer and centre pinch but not sure that is prudent! Lol. We have purchased a new compound slide base to give more stability but can’t fit without removing that pin. Any suggestions please? Thank you M |
JasonB | 15/09/2023 14:40:53 |
![]() 25215 forum posts 3105 photos 1 articles | I think from an earlier post you can just prize the round base off the compound now that the three screw shave been removed without worrying about the pin. Is there an opening on teh opposite side? I don't think there is so driving it out with a Flat ended poun dpunch or bar is not going to work. Sonetimes the imported machines have the insid eof the blin droll pins tapped so you can put a screw into them an dthen pull on the screw to remove the pin. |
JasonB | 15/09/2023 14:43:15 |
![]() 25215 forum posts 3105 photos 1 articles | Thought so image of my larger machine's one removed with pin still in place. You have even poste dpicture sof your topslide with the clamp plate and round bottom removed so if you have done it once it will come off again. Edited By JasonB on 15/09/2023 14:46:14 |
Margaret Trelawny | 15/09/2023 14:56:59 |
Thanks Jason - we gently (and I promise I mean gently) prized the two parts apart - and this happened! Now we are in a whole world of pain becase the stud thing is part of the slide?
Margaret Trelawny | 15/09/2023 16:14:55 |
100 forum posts 42 photos | We thought of a way around it. Drill the remains of the stud out, tap the saddle to M12, then make a new steel stud, tapped M12 into the slide. |
JasonB | 15/09/2023 16:46:47 |
![]() 25215 forum posts 3105 photos 1 articles | As there is no pulling force on the stud you could just loctite a piece of 12mm dia steel into a 12mm hole. |
Margaret Trelawny | 15/09/2023 17:03:49 |
100 forum posts 42 photos | That’s a great suggestion. Which Loctite do you recommend? I have seen Ade Swash etc use it be But never managed to see the part no. |
noel shelley | 15/09/2023 18:30:35 |
2308 forum posts 33 photos | Now thats what you call an open grain castiron ! As to loctite use what you have or can blag. They all work. Cleaning the hole is vital for good results - acetone or paint thinners - cellulose. Noel |
JasonB | 15/09/2023 19:00:13 |
![]() 25215 forum posts 3105 photos 1 articles | If you are going out to buy some then 638 or similar by another maker |
Margaret Trelawny | 15/09/2023 20:31:34 |
100 forum posts 42 photos | I am just wondering, would a threaded stud, tapped into the slide, be a better fix than gluing? I guess it would be stronger and although the piece doesn’t take any stress, it isn’t something I want to keep redoing if it fails.
M |
JasonB | 15/09/2023 20:40:16 |
![]() 25215 forum posts 3105 photos 1 articles | More chance of getting a true plain hole than tapping it. Same goes for (hand) threading a piece of bar M12 |
Margaret Trelawny | 15/09/2023 20:44:44 |
100 forum posts 42 photos | Very true. Ordering the Loctite now. Thank you. |
Howard Lewis | 16/09/2023 17:47:17 |
7227 forum posts 21 photos | I was going to suggest boring out / reaming both pieces and then Loctiting in a piece of silver steel Ah! Chicken and egg, you need the lathe operable to machine the two broken pieces! Possibly someone from the Copventyry Club would help you by doing the boring /reaming? Howard |
Howard Lewis | 17/09/2023 13:29:05 |
7227 forum posts 21 photos | You have two unread PMs! Howard |
