Bootlegger Blacky | 04/09/2023 16:54:00 |
![]() 54 forum posts 11 photos | Any ideas what these brass/bronze thingys are? |
Bootlegger Blacky | 04/09/2023 16:54:40 |
![]() 54 forum posts 11 photos | |
Bootlegger Blacky | 04/09/2023 16:55:06 |
![]() 54 forum posts 11 photos | What are they? |
Michael Gilligan | 04/09/2023 16:57:22 |
![]() 23121 forum posts 1360 photos | Looks like they could be part of a centrifugal clutch mechanism MichaelG. |
Dalboy | 04/09/2023 17:03:15 |
![]() 1009 forum posts 305 photos | I would not thought that it is part of a centrifugal clutch mechanism as they do not have any means of attaching a spring to hold it in to return them to the resting position when RPM lowers |
Michael Gilligan | 04/09/2023 17:16:00 |
![]() 23121 forum posts 1360 photos | But do you have any suggestion what they might be ? MichaelG. |
DC31k | 04/09/2023 17:22:25 |
1186 forum posts 11 photos | I have seen very similar, but with the boss on the outside of the curve, in a lever-operated lathe spindle-mounted collet chuck. The closing ring, to which the lever is attached, remains stationary and only moves forward or backward when operating the lever. The bronze slippers run in a groove in the part of the closing ring that rotates with the chuck. I must stress that the ones I have seen are inside out compared to the ones you show, so the above could be highly misleading. Edit: part number 7 in this drawing: https://www.model-engineer.co.uk/sites/7/images/member_albums/91402/893454.jpg Edited By DC31k on 04/09/2023 17:25:12 |
