david bennett 8 | 26/08/2023 21:59:36 |
245 forum posts 19 photos |
I was idly considering knife edges when it occured to me that a cylinder on two parallel knives would represent a circle rolling on a plane - almost the perfect description of a cycloid. I imagine this has been looked into before. Any suggestions where to look? The pic is just the general idea, but with the knives under the "pivots" to reduce rolling.(please view with bob at the bottom) dave8 Edited By david bennett 8 on 26/08/2023 22:01:21 Edited By SillyOldDuffer on 27/08/2023 10:45:27 |
Michael Gilligan | 26/08/2023 22:12:53 |
![]() 23121 forum posts 1360 photos | A nice friendly Moderator might rotate that picture for you, Dave Meanwhile … I think the first problem is that the radius of your cylinder is too small For the geometry to work, that radius would be the same as the length of the pendulum
MichaelG. |
david bennett 8 | 26/08/2023 22:27:13 |
245 forum posts 19 photos | Posted by Michael Gilligan on 26/08/2023 22:12:53:
MichaelG. Doh! i'm sure you are right, but wii have to work on getting my head round it. dave8 |
Michael Gilligan | 26/08/2023 22:52:51 |
![]() 23121 forum posts 1360 photos | I oversimplified, Dave … but this should give you a good sense of the required geometry https://iopscience.iop.org/article/10.1088/1361-6552/acd612/pdf It’s recent, and I’ve only just found it, so will be reading at breakfast. MichaelG. |
John Haine | 26/08/2023 22:56:53 |
5563 forum posts 322 photos | This has been analysed by Philip Woodward but alas doesn't result in isochronism. I could dig out the reference if interested. |
david bennett 8 | 27/08/2023 00:16:13 |
245 forum posts 19 photos | Posted by John Haine on 26/08/2023 22:56:53:
This has been analysed by Philip Woodward but alas doesn't result in isochronism. I could dig out the reference if interested. Thanks for the offer John, but I can now see that the correction should be a proportion of the pendulum length. In my idea, the correction would be in proportion to the roller radius, thus incorrect. dave8 |
John Haine | 27/08/2023 07:37:48 |
5563 forum posts 322 photos | Well for completeness it was in HJ August and September 1994. Intriguingly, he shows that if the roller rolled below a flat rolling surface it could work. Very strong magnets might do the trick, but then the rest of the pendulum would have to be non-magnetic to avoid magnetic forces interfering with gravitational. Edited By John Haine on 27/08/2023 07:41:55 |
SillyOldDuffer | 27/08/2023 10:56:01 |
10668 forum posts 2415 photos | I suspect implementation problems would make this difficult to build.
Got to be worth trying though. Perfect is the enemy of good! Dave
gerry madden | 27/08/2023 12:35:35 |
331 forum posts 156 photos | Posted by John Haine on 27/08/2023 07:37:48:
Well for completeness it was in HJ August and September 1994. ........ but then the rest of the pendulum would have to be non-magnetic to avoid magnetic forces interfering with gravitational.
He could still get 'inductive damping' (as in magnetic compasses), due to eddy currents |
david bennett 8 | 27/08/2023 14:57:16 |
Interestingly, when this idea came up I was playing about with these magnets and (steel) coins., and a steel plate. dave8 |
david bennett 8 | 28/08/2023 10:43:02 |
MichaelG. Michael, are you sure? I cannot reconcile this. Surely a roller of any size on a flat plane must produce a cycloid. The bob must follow this shape. dave8 |
John Haine | 28/08/2023 11:29:16 |
5563 forum posts 322 photos | The actual locus of the bob is a "prolate trochoid", not a cycloid. Woodward shows that the radius of curvature of this for small angles is greater than the circular path of the bob with no roller. This means that the "lift" of the bob for a given deflection is less than for a circle, whereas for a true cycloidal path it would be greater. In fact the circular deviation of a pendulum with roller suspension is greater rather than less than normal. Others have confirmed this numerically. Unless one could hang the roller on a magnet this means that there's no point in roller suspensions in an attempt to reduce circular deviation. Another point is that for compound pendulums (which all real pendulums are to a greater or lesser extent), it can be shown that there is no path the bob could follow that will be isochronous. There are some schemes to correct for circular deviation over a small range of angles, of which the most successful was probably the Fedchenko suspension spring. Or one can try to control CD to gain other benefits which is what Harrison's circular cheeks do. |
david bennett 8 | 28/08/2023 12:33:40 |
245 forum posts 19 photos | John, yes I can see that. I was viewing it as a "negative cycloid" But I was questioning Michaels assertion that the roller size mattered. I am experimenting with magnets. dave8 Edited By david bennett 8 on 28/08/2023 12:38:57 |
Michael Gilligan | 28/08/2023 15:50:31 |
![]() 23121 forum posts 1360 photos | Posted by david bennett 8 on 28/08/2023 10:43:02:
MichaelG. Michael, are you sure? I cannot reconcile this. Surely a roller of any size on a flat plane must produce a cycloid. The bob must follow this shape. dave8 . To be honest, Dave … no I’m not sure: … It was a knee-jerk reaction, and I would be perfectly happy to be proved wrong. … I was just thinking back to Huygens’ original, which is lodged firmly in my mind. Please experiment, and please advise !! MichaelG. . This is not it … but is a delightful image: https://commons.wikimedia.org/wiki/File:Cycloidal_pendulum_demonstration.png Edited By Michael Gilligan on 28/08/2023 15:55:56 |
Michael Gilligan | 28/08/2023 16:15:31 |
. Ian Bruce’s translation ^^^ is well-worth reading If you can’t find it on t’internet … send me a PM with your eMail address and I will send you the PDFs MichaelG. |
david bennett 8 | 28/08/2023 18:28:02 |
(general post) Hopefully, this will help with visuslising the problem with mounting the roller above the support plate. The two cycloids (inverted for clarity) represent a point on the underside of the roller and therefore the pendulum bob With the rod above the plate we get "A" With it below, we get "B" dave8 p.s. can our helpful moderator turn the image olease? Edited By SillyOldDuffer on 28/08/2023 21:45:31 |
david bennett 8 | 30/08/2023 14:04:42 |
A first quick and dirty try. The rod is 840mm by 3mm. The magnets and coins are as shown earlier. There is a good rolling action, but the rod is much to thin and long, allowing too much error in the bob (figure of eight) The amplitude falls from 90mm to 45mm in about two minutes. Such a terrible Q is not surprising, considering the work the pendulum has to do, and the rolling surfaces are so far unmachined. The magnets are very strong, and would hold a much heavier bob. dave8 , Edited By david bennett 8 on 30/08/2023 14:06:37 |
SillyOldDuffer | 30/08/2023 18:27:15 |
10668 forum posts 2415 photos | A gripping result! I'm having trouble conceiving how it works. Presumably low Q is caused by friction between coins and top-plate resulting from the magnetic force. I wonder if Q could be improved by increasing bob weight until gravitational force almost balances the magnetic force. I'm guessing friction follows the same rules whatever type of force brings two moving objects into contact. Does anyone know? Dave
david bennett 8 | 30/08/2023 20:51:36 |
245 forum posts 19 photos | Dave, don't let the coins fool you. They are the modern 2p coins that contaiin iron. As it is a rolling action, it doesn't feel frictiony. It should improve when the coins are replaced by chamfered discs to mimic knife-edges. Bear in mind the rolling action means the effort to physically lift the bob must come from the pendulum. I have ordered some differen sized magnets to hopefully tune the attraction. Also, a half second-sized rod might be better. dave8 |
Tony Jeffree | 30/08/2023 22:39:50 |
![]() 569 forum posts 20 photos | Intriguing idea. Just a thought - but would it help in tuning the behaviour of this setup if the coins/discs were running on a curved (rather than flat) track?
