Cutting a 1 1/8 fine pitch thread into PTFE!
Higgins199409/08/2023 15:55:24
25 forum posts
hi, i have been asked by a home chemist to turn a fitting for him so he can distill solvents from a paint an (dont worry i know the guy hes not a back yard meth chef hes a genuine home chemist inthusiast haha).
anyway one side of the fitting needs a 1 1/8 fine pitch thread put on it and ill turn a nut while im at it.
im fairly new to cutting threads on a lathe, i have a myford ML10, oud someone advice me on selecting what change gears i will need? currently i the only gears i have are a 65T, a 70T and a 75T lol.
any advice much appreciated
cheers,
josh.
Baz09/08/2023 17:12:54
1033 forum posts
All depends on what you or your mate consider a fine thread to be, how many TPI. I would strongly recommend purchasing a book on screwcutting, you would then be able to calculate your own gear train and know what gears to purchase. “The gearing of lathes for screw-cutting” by Brian Wood being one such book.
HOWARDT09/08/2023 17:19:41
1081 forum posts
39 photos
Soft plastics don’t like fine threads, they have no strength so tightening to seal can be difficult. If design allows much better to produce a metal adaptor with the fine thread one end and a course thread on the other to fit your ptfe part.
Brian Wood09/08/2023 17:37:31
2742 forum posts
39 photos
PTFE is a fairly rigid plastic which I think might be able to support a thread of 1.25 mm pitch. Gears needed for the gear train are 50, 55 and 70 set out as follows:-
Ist stud Driven 50, linked to Driver 55
2nd stud will need a suitable size idler to link the chain to the leadscrew---maybe 40 would be about right
Leadscrew 70
Result will be 1.247 mm pitch. very close to 1.25 as a target.
ML 10 lathes are unusual in that they have a permanent fixed 25T gear on the spindle, which in this case will need to mesh with the 50T wheel
Standard Myford change wheels are readily available
Regards Brian
Andrew Johnston09/08/2023 17:42:50
7061 forum posts
719 photos
I agree with Howard; I've just cleaned up a 2mm pitch thread in Delrin that had been crossthreaded for a friend. Only too easy to get it crossthreaded. So a finer thread in a soft plastic will be a nightmare.
Additionally PTFE is horrid to machine when trying to hold tolerances. It is soft and creeps rather than cuts. Cut, measure to size, and the next morining it will have moved.
Use the coarsest thread possible and ideally use glass filled PTFE. It is much more stable when machining.
Brian Wood09/08/2023 17:47:57
2742 forum posts
39 photos
Good advice Andrew. I will amend my thread pitch gearing accordingly and come back with something else. My sample of PTFE may not be typical.
Regards Brian
Brian Wood09/08/2023 17:58:04
2742 forum posts
39 photos
Josh could try for a 2.5 mm pitch thread, with the following set up:-
Fixed spindle gear 25 drives 25 on the 1st stud, that is linked to a 50 that drives a 70 on the leadscrew. As before, he will need an idler on the 2nd stud to complete the gear train and again a 40T gear might be suitable
The resulting pitch will be 2.445mm
Regards Brian
Clive Brown 109/08/2023 18:49:01
1050 forum posts
56 photos
Why are all of the suggestions for a metric pitch? Presumably the ML10 has an 8tpi leadscrew, or am I mistaken? If it is imperial, then I'd suggest 16tpi. Simple gearing, exact, and the half-nuts can be engaged anywhere.
After all, the OP is using imperial sized stock.
JasonB09/08/2023 19:27:10
Existing gears would give 24tpi which is an imperial pitch and not too far off something like 1 1/8" BSB @ 26tpi or M28 x 1
 Put the 75T on the leadscrew and use the others as idlers
if there is a hole through the adaptor that may dictate pitch if the wall is thin
Edited By JasonB on 09/08/2023 19:33:32
Brian Wood09/08/2023 19:34:28
2742 forum posts
39 photos
Simpler still would be to aim at 8 tpi, bearing in mind what Andrew Johnson has to say about the material. The gearing then is 25 on the leadscrew directly coupled to the spindle gear of 25T with idlers linking the chain
Macolm09/08/2023 21:04:46
185 forum posts
33 photos
Presumably distilling involves a fair range of temperature. PTFE has quite a high thermal expansion, roughly 1% over 0C to 100C, with a step change near room temperature due to a change of state. It would be better to redesign to avoid threading the PTFE, and to clamp it across a thin section to reduce the effect of the size change.
Edited By Macolm on 09/08/2023 21:05:28
John McNamara10/08/2023 04:16:36
1377 forum posts
133 photos
Maybe you could use a standard SS union coupling, Get one oversized and sleeve the the inside with flanged Teflon inserts so no chemical touches the SS coupling bores?
Edited By John McNamara on 10/08/2023 04:17:27
Howard Lewis11/08/2023 16:32:04
7227 forum posts
21 photos
Presumably, the thread does notb have to stand much axial load?
So DOES it have to be fine, or is it to mate with an already existing fine thread?
But, a fine thread In a relatively weak material, being shallow, will not be particularly strong.
Many threads in composites are coarse pitch, probably for that reason. If the fitting is purely for connection or sealing, a coarse thread may well be better, being stronger and more difficult to cross thread.
If the thread is 1.125" OD, use an Imperial pitch ( Why produce a "bastard" connection, for the sake of it? )
I know that from time to time we do, often for covenience rather than absolute need, but not an ideal choice.
To my mind, with an 8 tpi Leadscrew, I would feel tempted to go for 10 or 12 tpi. (8 tpi is an easy choice of changewheels ) with the others not far behind. 16 tpi might be getting a bit too fine to have a decent thread depth, only 0.040"in Whit form.
8 tpi will be 0.080" deep while 12 tpi is 0.0534", and 10 tpi will be 0.064".
David George 112/08/2023 08:13:12
2110 forum posts
565 photos
If you use an insert thread tool you can get a full form shaped insert which will form the crest of the thread as well as the root of the thread as long as you use the correct insert for the thread that you choose. this will trim any miss formed thread when you come to the corect depth of thread you are cutting. Have a look at APT tool web site.
have a look at cutting a thread on my lathe recently although it is in bronze but 8 TPI https://youtu.be/7IgjID3RHkQ drop me a message if you want any further info.
David
