Off the shelf stand for Armadeal CJ18A mini lathe.
Gary Yeadon | 14/07/2023 00:01:16 |
![]() 7 forum posts | Has any modellers purchased an off the shelf for the above mini lathe? |
Hollowpoint | 14/07/2023 08:40:13 |
550 forum posts 77 photos | THIS should fit. 🙂 |
not done it yet | 14/07/2023 11:08:06 |
7517 forum posts 20 photos | Ask Amadeal? If nothing, ask them for a sensible referral? Arc option is likely good, but depending on your location, collection from the other mini-lathe suppliers might be of benefit to the wallet. Personally, I might check out Arc, Warco, Axminster, Chester, etc and choose one that appeals, or is close enough to collect (if the cost is important). Google is likely your best friend. Other options might be ebay, gumtree, twitface marketplace. Likely not new, but depends on what you actually mean by ‘off the shelf’. |
Howard Lewis | 14/07/2023 20:23:13 |
7227 forum posts 21 photos | Chances are that many of the already available mini lathe stands may either fit, or can be redrilled to suit the bolt spacing for the Amadeal. If all else fails, you could fabricate your own stand. FWIW my advice would be; once the stand is firmly in place, use Rollie's Dad's Method (As detailed in Ian Bradley's "The Amateur's Workshop", and advised by Myford ), and elsewhere, to remove twist from the bed, to maximise accuracy. Howard. |
