Ian McVickers | 12/07/2023 21:01:30 |
261 forum posts 117 photos | Hi all, Ive finally managed to get my PM Research No 4 nearing completion and running on air. Video here https://youtu.be/e2f2Lar4r8M I still have drip feed oilers to make for the stand,probably similar to the other 2 and was also thinking about a lid for them. This was definitely a challenge to machine especially the stand. I will probably put the flywheel back on the lathe and redo it as I`m not happy with the finish and see about improving it. There is also a bit of wobble on the fly wheel due to the crank not being perfect but I will blame it on it being in 5 pieces and a pain to get true. |
JasonB | 13/07/2023 06:52:58 |
![]() 25215 forum posts 3105 photos 1 articles | Looks to be running well. Regarding the crankshaft it is usual to make them from 4 pieces with the shaft full length and then cut out the middle of that once it has been assembled which helps keep the shaft straight. |
Ian McVickers | 13/07/2023 18:02:39 |
261 forum posts 117 photos | Thanks Jason. I assembled it as per the drawings and it was straight after assembly but isnt now. Its not out by much so maybe when I redo the flywheel I might attempt to straighten it out. Just noticed the spelling mistake in the thread title, can this be fixed? |
Blue Heeler | 21/07/2023 07:32:29 |
![]() 342 forum posts | Very nice build of a No4.
