Tube needed
george baker 108/07/2023 12:40:34
39 forum posts
Hi
I need some tube 3mm id, 0.5mm wall thickness and 4mm id, 0.5mm wall thickness, an inch or so would be enough. Material, metal, but what is not too important.
Any idea where I get/Buy some?
An off cut from an electronic connector, tube from an aerosol ?
I maybe able to make a do with some solid plastic.
Thanks
George
JasonB08/07/2023 13:22:32
How critical are your sizes?
5/32" x 24swg tube in brass and copper is readily available but will be about 2.9mm ID try M-machine
K&S and Albion do 4mm OD in various metals but with a 0.45mm wall so 3.1ID
Keith Long08/07/2023 13:27:12
883 forum posts
11 photos
Try a local model shop, Albion Alloys produce pretty much what you're after as telescopic tubing, ie adjacent sizes are a sliding fit in each other. If no local model shop then Chronos list it as do Hobbies or Hobbys. A quick internet search will come up with plenty of stockists.
george baker 108/07/2023 14:02:55
39 forum posts
Hi
thanks folks. I will try to check them out but since I only need an inch....
I was standing in the kitchen, looked at the radio and thought "Telescopic Antenna", now it's just the sizes. 3mm is critical, 4mm = 3mm + 2*0.5 ( wall thickness) so not vital.
George
ChrisLH08/07/2023 15:10:59
111 forum posts
7 photos
If all else fails find a friend with a lathe, you'll be able to have the exact sizes you need then.
george baker 108/07/2023 16:13:38
39 forum posts
Hi
Thanks, but the lathe is not the problem, it's the wall thickness, it wouldn't 3D print either.
George
Old School08/07/2023 17:38:33
426 forum posts
40 photos
What’s the problem with the wall thickness, 0.5mm is 20 thou easy to do on a lathe.
Old School08/07/2023 17:43:27
426 forum posts
40 photos
The tuned pipe on this car has a wall thickness of 12 thou all machine from the solid using sharp HSS tools.Car
Emgee08/07/2023 18:09:31
2610 forum posts
312 photos
Posted by Old School on 08/07/2023 17:43:27:
Interested to know if you are using threaded parts on the various joints of the tuned pipe.
Emgee
MadMike08/07/2023 18:29:58
265 forum posts
4 photos
Why don't you just get some 4 and 5mm bar and simply drill, o team to size if the bore is critical.
Grizzly bear08/07/2023 18:59:50
337 forum posts
8 photos
George,
Madmike has given you the answer, in my opinion.
You do not state what the tube is for (Another secret mission).
Bear............
george baker 108/07/2023 19:09:36
39 forum posts
Hi
Yep, looks like MadMike has it sorted.
It's for a magnetic catch, I bought the magnets before I decided how to make the holder
George
Grizzly bear09/07/2023 18:00:38
337 forum posts
8 photos
Hi George,
Thanks for the update, I hope it goes well.
Bear..........
