Steve Crow | 02/07/2023 14:40:22 |
429 forum posts 268 photos | I'm stripping down this drill press for rehabilitation and I want to remake some parts. I don't know the first thing about Imperial threads as I generally use metric or BA (Yes, I know BA is technically metric). The thread on the spindle nose seems to be 3/8" x 40tpi which I assume to be a ME thread. The screws for locking the table are 3/16 x 32tpi. I whipped out my Zeus charts and found a match with BSF. Looking for taps and dies though, I found the same size/pitch available in UNF and UNS as well as BSF. I think that UNF and UNS might be the same thing but are they interchangeable with BSF? Steve |
JasonB | 02/07/2023 14:50:16 |
![]() 25215 forum posts 3105 photos 1 articles | BSF is 55deg while the UN ones are 60deg |
Steve Crow | 02/07/2023 15:02:07 |
429 forum posts 268 photos | Posted by JasonB on 02/07/2023 14:50:16:
BSF is 55deg while the UN ones are 60deg Just rechecked my Zeus and realised that! I'm going to have to try and measure the angle. Maybe compare to a known 60 degree thread? |
DC31k | 02/07/2023 15:42:15 |
1186 forum posts 11 photos | Posted by Steve Crow on 02/07/2023 14:40:22:
I think that UNF and UNS might be the same thing... If they were, why would there be two names for the same thing? UNF is the standard Unified fine series. UNS is generally Unified special. Also, it would be unusual to use fractional dimensions below 1/4" in Unified threads. Below 1/4", they are normally referred to by numbers (e.g. 10-24 UNC). I think it might be unwise to try to fit the spindle nose into any series as such. A spindle nose is a different category of threaded item to a fastener. Perhaps go through every fastener on the machine and list diameter and thread pitch. Hopefully you will find something that belongs to one series or the other but not both. It would then be reasonable to assume that the others belong to that same series. |
Robert Atkinson 2 | 02/07/2023 17:59:23 |
![]() 1891 forum posts 37 photos | UNF and UNS are technically different but many suppliers use them interchagably for fine threads. For example 3/8-32 is a common thread in electrical items. I have seen this quoted as both UNF and UNS by component and tap / die suppliers. Robert. |
DC31k | 02/07/2023 18:13:24 |
1186 forum posts 11 photos | Posted by Robert Atkinson 2 on 02/07/2023 17:59:23:
For example 3/8-32 is a common thread in electrical items. I am wondering if that is a typo.? 3/8-32 as a member of UNF just does not make sense. |
Harry Wilkes | 02/07/2023 18:28:43 |
![]() 1613 forum posts 72 photos | Steve imperial tap's and die's both BSW & BSF are still easy to obtain H |
Steve Crow | 02/07/2023 18:39:31 |
429 forum posts 268 photos | I am referring to 3/16" fasteners. The spindle nose is 3/8" 40tpi. I tried a UNF screw (10-32) and it didn't fit so I'm assuming it BSF. The original screws mate with threaded brass bushes, loosely fitted in the castings so I'm going to replace them with M5. Steve |
Swarf, Mostly! | 02/07/2023 18:44:14 |
753 forum posts 80 photos | Posted by DC31k on 02/07/2023 15:42:15: SNIP! . A spindle nose is a different category of threaded item to a fastener. SNIP! Thank you, DC31k, for making this point. And it's not the only member of that category. I feel that this could, with great benefit, be expanded into a key paragraph as part of Chapter 1 of the next book anybody writes on screw threads. Best regards, Swarf, Mostly! Edited By Swarf, Mostly! on 02/07/2023 18:46:54 |
Robert Atkinson 2 | 02/07/2023 19:11:28 |
![]() 1891 forum posts 37 photos | Posted by DC31k on 02/07/2023 18:13:24:
For example 3/8-32 is a common thread in electrical items. I am wondering if that is a typo.? 3/8-32 as a member of UNF just does not make sense. Oops yes. Should be UNEF (UN Extra Fine) |
Michael Gilligan | 03/07/2023 08:57:06 |
![]() 23121 forum posts 1360 photos | It’s irrelevant now, Steve, because you’ve decided to Metricate the job … but there’s a good illustration of the Whitworth thread-form on this Wikipedia page: **LINK** https://en.wikipedia.org/wiki/British_Standard_Whitworth … it was all rather elegantly contrived. MichaelG. |
