Tony Ray | 17/06/2023 13:57:08 |
238 forum posts 47 photos | Can anyone assist with some thread dimensions for the 4 off front plate retaining screws please? This is the early type with non-standard screws and whislt I have sucessfully made the scroll retaining screws 0.155" x 48 TPI and the +/- adjuster 36tpi, I just can't work out what TPI the 0.155" dia retaining plate screws should be. I have tried 36, 48 and now 40 TPI. I have assumed that whatever it is is 55 degree due to the age of the head. If someone is able to measure the O/D and TPI of an existing screw that would be a great help. In addtion can anyone offer advice on the correct tip width and thread depth for a nominall 0.155" Whitworh form ? It seems that the thread depth of 0.640327p and a radius of 0.137329p where p is the pitch. isn't working out for me I'm taking the calculation to be 0.640327 * (1000/40) = 25 i.e. 0.025" or 0.635mm single depth of thread and the radius to be 0.137329 * (1000/40) = 3.43 or 6.86" (0.14mm) across the dia. I'm working on the basis that is the tip is a little narrow I'll need to dept a little more but trial so far are leaving a razor sharp crest if I depth anywhere above 0.022" Matters are helped by havein no screw to work from and the threaded holes being so narrow and seemingly worn . I know I can buy them form eg Wiseman (cost as yet unknown) but as I need to make the front plate in for a penny ... Thanks
bernard towers | 17/06/2023 14:35:13 |
1221 forum posts 161 photos | I very much doubt that the crew holes are worn as they are through hardened. I will try to measure my screws and see what I come up with. |
peak4 | 17/06/2023 14:54:06 |
![]() 2207 forum posts 210 photos | I can't remember where I found then, so can't provide a URL, but I've just uploaded a couple of scan/photos to my albums |
Tony Ray | 17/06/2023 15:28:56 |
238 forum posts 47 photos | Hi Bernard, Thanks appreciate the help, its all a bit odd, had it not been hardened I would probably have re threaded them by now. I suggested wer as everything I have cut thus far tightens up the deeper the thread is wound in, hothing I have tried thus far seems 'right'.
Thanks Peak, I use this as my starting point, a real nusiance that they don't quote TPI. |
DC31k | 17/06/2023 17:08:15 |
1186 forum posts 11 photos | Posted by Tony Ray on 17/06/2023 15:28:56:
Thanks Peak, I use this as my starting point, a real nusiance that they don't quote TPI. It is not usual to quote tpi for a BA thread, primarily because it is generally assumed they would be die cut rather than screwcut; secondarily because BA is a metric pitch. Thirdly, the pitch progression of the thread series follows a geometric mathematical series leading to numbers that are difficult to produce with change gears. The slotted front plate screw for the 1/2" head is given as 3BA. 3BA is 0.9^3 = 0.729mm pitch which is 34.8 tpi. |
peak4 | 17/06/2023 17:44:43 |
![]() 2207 forum posts 210 photos | OK I'm struggling to measure the screws on mine, as they are a bit worn and gnarly. Just eyeballing the thread, it does seem to fall between 4 and 5 BA at 0.0260" & 0.0232" respectively, as far at pitch goes, but just undersize diameter for 3BA; that said, I'm on the waiting list for a cataract operation. Alternatively, try Wiseman
Edited By peak4 on 17/06/2023 17:56:47 |
SillyOldDuffer | 17/06/2023 18:46:51 |
10668 forum posts 2415 photos | Posted by DC31k on 17/06/2023 17:08:15:
Thanks Peak, I use this as my starting point, a real nusiance that they don't quote TPI. It is not usual to quote tpi for a BA thread, ... True, but this USA website does. Small fasteners on British equipment are often BA. After finding Whitworth threads were unsuitable for Electrical and Instrumentation type work, the British Association set up a committee to define a good alternative and they came up with a logical metric thread. So far so good except they made BA dimensions a bit odd by converting them to inches! Even numbered BA are more usual, so likely panel holding screws are 4BA=0.66 (38.5tpi), 6BA=0.53 (47.tpi), 8BA=0.43(59.1tpi) How close your lathe can get to these pitches depends on what change wheels are available. On my machine I can do:
Closer is possible by doing the sums. The required decimal ratio is converted to a series of increasingly close integer ratios by calculating converging fractions. For example, pi is approximately 3/1, 22/7, 333/106, 355/113, 103993/33102 etc. Then gears are made to implement the ratio on a banjo. More hard work! Also, the thread angle is 47.5° not 55 or 60. All very tedious so I'd just order some ready made BA screws off the internet and fit them! Dave
Tony Ray | 17/06/2023 20:55:00 |
238 forum posts 47 photos | Thanks everyone, sorry I missed the BA listings Inthink the chart I have is similar but missing that info. I have a fair range of BA taps & dies, my Dad a watchmaker, spent the last part of his career in instrument making, I know iI have 3BA taps not sure about dies. I agree it would be easier to buy them. Anyway I’ll have a look tomorrow. |
Tony Ray | 17/06/2023 21:22:50 |
238 forum posts 47 photos | Ok I couldn’t wait until tomorrow. I just ran a 3BA die over my best attempt a 40 TPI Whitworth approximation and it just removed a little material but it’s made a substantial improvement to the feel. Luckily the die is split so I can adjust the fit. I suppose the statement an out the high cost of spares for the CHS is based on the lack of readily available info on what is required. |
peak4 | 17/06/2023 22:21:41 |
![]() 2207 forum posts 210 photos | Just re-reading my earlier comment; seems to have acquired a misplaced decimal point, and should of course read Edited By peak4 on 17/06/2023 22:22:26 |
Tony Ray | 18/06/2023 07:30:31 |
238 forum posts 47 photos | Thanks Bill, I knew the screw should be about 0.155” and being a metric man I didn’t see the error. I do however need magnification to see what’s going on when cutting threads at that diameter. My Dad showed me a very fine fusee chain and told me they were made by children as they could see what they were doing. |
Nicholas Farr | 18/06/2023 08:28:26 |
![]() 3988 forum posts 1799 photos | Hi Tony, a similar question was asked in Coventry Die Heads Regards Nick. |
JohnF | 18/06/2023 09:47:07 |
![]() 1243 forum posts 202 photos | Maybe Wiseman Threading tools can assist try this link Wiseman |
