Rick Jackson | 11/06/2023 21:23:59 |
2 forum posts | Hi, |
not done it yet | 12/06/2023 09:52:05 |
7517 forum posts 20 photos | It is unlikely that the machine has ‘reached the end of the road’ if the owner is determined to repair it - but it does rather depend on how much that wear might be and the skill and determination of the repairer. It is often simply a case of economics, but sometimes a matter of dogged determination on the part of the user. A minimal amount of wear could, on the other hand, not be too important for many users. They are not often used for very precise duties. |
Hopper | 12/06/2023 09:58:17 |
![]() 7881 forum posts 397 photos | There was an article in MEW many years ago about shrink fitting a thin brass sleeve over the quill of a drill press then boring out the cast body to fit the sleeve. That would be one way of doing it. Another would be to sleeve the holes in the cast body to fit the quill. Yet another could be to put a slit/s in the body and add pinch bolts to squeeze the body in to match the quill. Some old drill presses were made with this feature included. |
Brian Wood | 12/06/2023 10:01:27 |
2742 forum posts 39 photos | I've lived with some slop in the lower part of the housing on an old Progress drill for 40 years, it still drills holes and well enough for pretty much all requirements. Brian |
Craig Brown | 12/06/2023 10:13:49 |
110 forum posts 57 photos | How are you determining that there is wear between the quill and the body? Import drill presses are notorious for a sloppy fit here but on a Fobco the tolerances are normally very good and it would have had to have been quite seriously neglected and or abused to introduce enough wear to make it unserviceable |
SillyOldDuffer | 12/06/2023 10:54:15 |
10668 forum posts 2415 photos | Posted by not done it yet on 12/06/2023 09:52:05:
It is unlikely that the machine has ‘reached the end of the road’ if the owner is determined to repair it - but it does rather depend on how much that wear might be and the skill and determination of the repairer. It is often simply a case of economics, but sometimes a matter of dogged determination on the part of the user. ... +1. Most businesses have an accountant keeping a close eye on the cost/benefit ratio of owning machines. They compare the cost of repair with the cost of replacing, and there comes a point in the life of working machines when they are all declared 'BER', Beyond Economic Repair, When that happens the machine is out the door. May still be worth repairing, especially in amateur ownership. As labour is expensive, businesses are more ruthless about BER than hobbyists. The question is, how much time and money do you want to spend fixing an old drill rather than using it? The cost of spares is often a shock - second-hand prices do not apply to new parts! And if one thing is worn out, the chances are other parts are iffy too. The repair could be a long job, which stops work on everything else. Might not matter to you because restoring old machines is a rewarding hobby in itself. Restoration isn't for me because I have other priorities. I admire the people who rebuild the mangled remains of crashed WW2 aircraft after 80 years in a peat bog and get them flying again, but it's not for me. Likewise - just me - I wouldn't put much effort into a pillar drill because most of my precision drilling is done by a mill. I expect you'll get conflicting answers. Chaps who love old machines will recommend fixing it, whilst others wouldn't bother. Where are you? Maybe a local Fobco expert could take a look and advise. Dave |
Andrew Johnston | 12/06/2023 11:19:35 |
![]() 7061 forum posts 719 photos | How much wear? Does it affect drilling holes? Drill presses are not precision tools, so unless the wear prevents holes from being drilled I wouldn't worry about it. Andrew |
Nicholas Farr | 12/06/2023 12:03:13 |
![]() 3988 forum posts 1799 photos | Hi Rick, I've used many worn / clapped-out drill presses during my day jobs, some with quite q lot of slop in the quill, but like Andrew said, if they drill holes what's the worry. It is surprising how even a very wobbly quill, will drill quite a true hole, providing the drill bit is decent. In my last day job, I had to tap a good number of M8 holes using a auto-reverse tapping head, which it did without any problems, and that was with a really worn sloppy quill. Picture below is not the best quality, as it's taken from a video recorded on my old phone. Regards Nick. Edited By Nicholas Farr on 12/06/2023 12:05:04 |
Jeff Dayman | 12/06/2023 12:29:14 |
2356 forum posts 47 photos | If the problem with wear on the OP's machine is causing the table to sag at the front, so the drill is no longer square to it, a simple prop made of a heavy threaded rod and long nut can be used to get it square for a job. The prop is fitted between the table and base, and the table front jacked up under the table while checking between table and drill for square. If the wear is not huge sometimes shims of brass or aluminum sheet can be placed between column and table collar. If these work they can be loctited in place. Crude, but these methods work, at minimal cost and effort. A drill press is not a precision hole making tool but a badly worn one can still be adjusted to do plenty of work. If the table won't clamp securely to the column don't force the clamp screw, it may break. Adding some shims may also help clamping. |
Rick Jackson | 13/06/2023 22:05:57 |
2 forum posts | Hi and thank you all for your replies. |
Nicholas Farr | 13/06/2023 23:13:01 |
![]() 3988 forum posts 1799 photos | Hi Rick, used a few press drills like that in my time, so not unusual for a machine of that age if it spent most of its time in industry. You should however clamp your work down when drilling on a new or old machine. Regards Nick. |
DMB | 14/06/2023 07:18:15 |
1585 forum posts 1 photos | Nick, quite agree, I now always clamp down. I have busted very few drills over the years but I had a surprise in recent times. I thought that keeping below 3/16"dia., I might get away with no clamp. Work in very heavy 5" drill vice not bolted down, the 3/16" drill jammed, wrenched drill vice handle out of my hand, vice spun round and chucked off table down on to bench and busted drill. Lesson learned! John |
Clive Brown 1 | 14/06/2023 09:00:17 |
1050 forum posts 56 photos | Posted by Rick Jackson on 13/06/2023 22:05:57:
At full extension, there is about 1mm movement.
The play that you describe won't help, but the drill point runout could be due to the drill bit being slightly bent. I've found this defect regularly over the last few years, particularly with "budget price" drill sets. Probably not too noticeable with my hand-held diy drill but very noticeable in my Fobco until, as you say, the drill starts cutting full diameter. I should say that my machine doesn't have noticeable play in the spindle. As for the chuck, I would suggest putting in a short, straight length of round rod, say a HSS lathe tool blank or silver steel, and seeing how true that runs, especially with the spindle lock tightened. Chuck removal, if needed, might be done with wedges, search this forum. Replacement Jacobs jaws are / were available. When I first got my Fobco, I found the best method was trying to use a 1/2" endmill in it. The chuck detached instantly, but not recommended. Edited By Clive Brown 1 on 14/06/2023 09:03:11 |
Kiwi Bloke | 14/06/2023 09:31:41 |
912 forum posts 3 photos | Around the time Fobco ceased trading, I saw a turquoise-coloured, apparently factory-fresh example. Its ball handles looked a bit rough, and the quill rattled horribly in the main body. I wondered whether this was a trial model from a cheap-labour contract sub-manufacturer, or whether Fobco cobbled together reject parts to flog off. If that was the best they could do, the world's better off without them. Pity, because the cream-coloured ones were good machines, although I thought the belt section was too large for the small pulleys. I would very much have liked the bigger model... |
Nicholas Farr | 14/06/2023 10:50:21 |
![]() 3988 forum posts 1799 photos | Hi Kiwi Bloke, one of the worn out drills I had to use in one of my day jobs, was one of those Fobco cream coloured floor standing ones, this had about the same amount of slop that Rick has described with his. The clamping on the table to the column was also well worn, which was probably as much on the top end of the column, and you had to use an extension tube to get the table tight enough to hold it at any position on the column, but it still drilled very good holes. Regards Nick. Edited By Nicholas Farr on 14/06/2023 10:52:20 |
