1st 3d Print(er)
iNf04/06/2023 22:09:48
58 forum posts
46 photos
Inordinately pleased with my 1st attempt at 3d printing blush
After spending ages debating wether to buy a printer, a sale on the creality website resulted in an Ender S1 Pro heading my way.
The start of a steep and slippery path with zero 3d and CAD experience.
The following design was created in the Onshape app on an Android tablet. As far as I know it's the only CAD app you can create/modify 3d models, other CAD apps just being viewers only.
Finished print with minime prototype smiley
This was the 3rd attempt at printing this, the original was going to be slightly longer but was to long to fit on the bed so an attempt to print it vertically was curtailed by me when I realised it was going to take nearly 2 days! Due to the whole model having to be filled by supports. All part of the learning process. The 2nd attempt was also curtailed when some muppet blush turned off the power for the house ring main forgetting the only socket in the workshop spurred from the house circuit was the one that the printer was plugged into! A resume printing function was initiated and printing did resume but as the bed had cooled the base detached.
3rd time lucky yes
lee webster05/06/2023 08:09:47
383 forum posts
71 photos
A very interesting object! Nicely done.
3D printing is the only way I could make patterns and moulds for casting. It's an amazing process.
Packmule05/06/2023 08:13:07
133 forum posts
6 photos
Fusion 360 is available free for personal use.
Bob
iNf05/06/2023 09:53:59
58 forum posts
46 photos
Posted by lee webster on 05/06/2023 08:09:47:
It's not that interesting I'm afraid. It's just a pen, paper and cordless phone holder to fit in a niche in the wall !
Roderick Jenkins05/06/2023 10:34:59
2376 forum posts
800 photos
Hi iNf
I took advantage of the same sale to upgrade to the 3 S1 Pro. Very impressed with the first print straight out of the box. I've put mine in an enclosure and have have managed, after a bit of parameter tweaking, to print some distortion free artifacts in ABS with the aim of moving on to nylon as a more engineeringy material than PLA.
Enjoy your new toy,
Rod
Edit to correct iNf auto correct angry
Edited By Roderick Jenkins on 05/06/2023 10:38:46
iNf05/06/2023 11:21:41
58 forum posts
46 photos
Hi Rod
I would be interested in details of your enclosure and ABS settings.
Thanks
Bazyle05/06/2023 11:47:33
6956 forum posts
229 photos
Interesting that you should try a large item as your first print. Mine was a 1cm cube to measure accuracy followed by a small 1 module changewheel.
Rod - you might want to consider PETG but will be interested to hear more about your results if you do go for nylon.
Roderick Jenkins05/06/2023 11:58:38
2376 forum posts
800 photos
Dave,
One of these **LINK**
The settings in Cura are generic ABS but:
bed temp is 110
initial layer temp 270
printing temp 240
I used a 8mm brim and adjusted the Z height so that the brim lines are barely distinguishable i.e. well squashed down on to the PEI bed. I didn't use any adhesive on the bed.
HTH,
Rod
iNf05/06/2023 13:34:01
58 forum posts
46 photos
Thanks Rod
I've not explored different layer settings yet, so a lot to learn.
Bazyle
I suppose the prototype was my actual 1st print and that's quite small. As it printed ok I thought I'd give the full-size one a go smiley
John Doe 205/06/2023 14:46:37
441 forum posts
29 photos
Very nice print, iNF.
Shapr3D is a CAD App specifically designed to work on an iPad or a computer. I have been using it for a few months, and it seems very good, although I have only used 2D TurboCAD before and none of the others available.
3D printing is just brilliant. I can wake up with an idea in my head, then CAD it and set it printing to be ready that afternoon or the next morning. Even silly little things, such as A replacement lid for our bird feeder; Brackets to repair the clothes drying horse; A jockey wheel for a child's toy caravan, A holder for a set of specialised plumbing tool sockets which have a round profile but a large flat on one side, New plastic soft jaws for my crab clamp....The list goes on, and be warned; it gets addictive !
To make those in a machine shop would require a workshop and thousands of pounds worth of lathes, mills and tooling, plus I don't have the skills, experience or accuracy to work in metal. I don't know how you would even begin to cut the shapes for the plumbing sockets.
When you have a moment I would be interested in the advanced settings employed in your Cura if that's what you are using to slice:
Outer wall wipe distance, (0.3mm)
Infill wipe distance, (0.15 mm)
Retraction distance, (7.00mm)
Retraction speed, (25.0mm/s)
Retraction retract speed, (25.0mm/s)
Retraction minimum travel, (1.5mm)
My settings in brackets, for PLA filament.
With PLA I am getting a lot of stringing where the nozzle moves between elements on my prints, which require a lot of post print finishing, and I would like to reduce this.
I have not used ABS yet, but had trouble with PETG detaching, until I put the bed temperature up to 80°C.
Nylon was difficult, and really needs an enclosed print space apparently.
iNf05/06/2023 16:02:35
58 forum posts
46 photos
Posted by John Doe 2 on 05/06/2023 14:46:37:
I'm afraid I don't know the advanced settings as I just selected the profile for my printer in the version of cura that came with it. Judging by the guide that came with the printer your Retraction settings are a lot different.
Regarding Shapr3D, it doesn't appear to have an Android app and the free version seems very restricted, whilst Onshape seems to have few restrictions and can work on any platform. I've not yet used it on the PC and solely used the android app to design/draw my print.
John Doe 210/06/2023 16:33:40
441 forum posts
29 photos
Many thanks for the info yes
Justin Thyme12/06/2023 08:37:27
72 forum posts
it is isn't it. can make so many clever little things that otherwise would never be attempted. Just from this weekend, we need to add a vent to a machine, so was able to make a 6" to 4" connector and a little bracket to hold the 4 inch pipe to the wall.
