Robert Atkinson 2 | 21/05/2023 18:59:57 |
![]() 1891 forum posts 37 photos | I went to the Dunstable Downs amateur radio car boot sale today. Cost was minimal, £40 for the Pultra, £10 for the drill and £4 for the smalls. I did get a few items of test equipment too. Robert. |
Michael Gilligan | 21/05/2023 19:28:19 |
![]() 23121 forum posts 1360 photos | Posted by Robert Atkinson 2 on 21/05/2023 18:59:57:
[…] Cost was minimal, £40 for the Pultra . Nice one, Robert … let’s see some photos, please MichaelG. |
Nigel Graham 2 | 21/05/2023 19:39:30 |
3293 forum posts 112 photos | You did well there, then! |
DiogenesII | 21/05/2023 19:42:44 |
859 forum posts 268 photos | That's an impressive haul! ..what a pleasing day's work.. |
Robert Atkinson 2 | 21/05/2023 20:42:09 |
Michael Gilligan | 21/05/2023 20:54:49 |
![]() 23121 forum posts 1360 photos | Excellent !! On that Manchester bed, I suspect it may be a ‘bitza’ … but there’s nothing much wrong with that: They were sufficiently tightly toleranced that components were considered interchangeable. MichaelG. Edited By Michael Gilligan on 21/05/2023 20:55:41 |
Michael Gilligan | 21/05/2023 21:13:42 |
The series P … of which these are the beds, had a headstock more like a watchmaker’s lathe . . MichaelG. |
Robert Atkinson 2 | 21/05/2023 21:37:47 |
![]() 1891 forum posts 37 photos | I did wonder about the different finishes. At £40 including the chucks I was not too bothered |
duncan webster | 22/05/2023 01:00:42 |
5307 forum posts 83 photos | I think I've got a Pultra cross slide squirrelled away somewhere. I'll have a ratch ASAP and let you know. |
duncan webster | 22/05/2023 12:09:29 |
5307 forum posts 83 photos | Looks like today is your lucky day, not only a cross slide but the bit that bolts to the bed. I don't have any evidence that these are from a Pultra, but they look very similar. The pen is 142mm long. What I don't have is the very nice resettable dial, that was grafted onto a Cowells, which I've since sold. I have a feeling (no more than that) that I have another cross slide lurking somewhere, but I've been dragged out to attend to family stuff. Any more dimensions wanted just shout. If you're interested make me an offer Edited By duncan webster on 22/05/2023 12:11:04 |
Robert Atkinson 2 | 22/05/2023 12:59:07 |
![]() 1891 forum posts 37 photos | Hi Duncan, Message sent. Robert. |
Robert Atkinson 2 | 28/05/2023 14:37:37 |
![]() 1891 forum posts 37 photos | Got a chance to have a closer look at the Pultra today. Befinately earlier bed. There was a CF-33 recessed collet in the headstock and I was a bit worried it might be stuck. The drawdar unscrewed by hand abd collet came right out. The 3 and 4 jaw chucks don't seem to have arbours to fit the headstock but the should not be a problem as balnk 10mm arours are available. The 3 jaw is a Bernard. It was left closedand has a bit of rust. The lever tailstock is also stuck so bothe of those have had a liberal application of Plus-Gas and are now soaking. There is a Jacobs style chuck with arbour and drawbar the fits the tailstock
Robert Atkinson 2 | 29/05/2023 15:42:56 |
![]() 1891 forum posts 37 photos | I did some more work on the seized tailstock today. It's a lever operated model from a P type. I left it in a ziplock bag with plenty of Plus Gas to soak overnight. Still totally solid this morning and not responding to taps with a piece of wood on the tube while hand holding the tailstock. So I got the bed out and cleaned up the ways with steel wool and a bit of kerosine. They are in good condition but had one small, obviously recent, ding wirh a raised area. I dressed that off with a diamond file. I also cleaned up the exposed parts of the tailstock tube. Then fitted the tailstock to bed and clamped it with a piece of wood between the base of the tailstock and head. This gave me some mass to react force on the tailstock tube without having to over clamp it. I then warmed it up to about 40 deg C and applied more penetrating oil. Left it for an hour and tried a few light taps with a bit of wood. No movement. Time to bring out the heavy(er) kit. I applied lots of heat to the body of the tailstock with the hot air gun and tapped the tube from both ends with a small dead-blow hammer and a piece nylon to protect the tube. As soon as it moved one way I cleaned the rust off the exposed part with steel wool, turned the tailstock around on the bed re-applied Plus Gas and tapped it back until it exposed a bit of the other end. Rinse and repeat until the tube came out I then cleaned the tube, the bore of the tailstock. and the locking slide. The precision and quality of these lathes is shown by the fit of the locking slide until I cleaned the outside of the slide and applied Plus Gas it was not obvious that this was a separate piece. Even after cleaning the plate slides in the slot with no detectable play and no obvious movement between locked and unlocked. It's coming together. Robert. Edited By Robert Atkinson 2 on 29/05/2023 16:13:06 |
