Size of recess in Holder for Die
Howard Lewis | 09/04/2023 16:06:10 |
7227 forum posts 21 photos | Needing to produce a 3/4 x 10 BSW thread, I have been loaned a tao and a Die. But having no holder for a 2" OD Dies, I need to make one. Not wishing to over expand the Dies, and crack it, I want to know thew maximum diameter of the recess in the holder., so that the Dies can be adjusted to produce a correctly sized thread. (Screrw cut almost to size and then finish with the Die. Despite sewsrching in my booksm and an hour's search, on line, have been unable to find anything, other than that the tolerance on Die diameter is + / - 0.008" So should I botre the holder to 2.010", or dare I safely go a shade larger ? Howard
Ian Parkin | 09/04/2023 16:32:59 |
![]() 1174 forum posts 303 photos | Howard just been to measure my die holders…i have a few 2” ones and they are all 18-20 thou over 2” |
Howard Lewis | 09/04/2023 17:19:05 |
7227 forum posts 21 photos | Ian, Thank You Was wondering if +010" mwould be too much (havong been loaned the tooling it would be a disaster to over expand the Die and crack it. Think that I'll get bnracve and bore the holder to 2.015" and tread very carefully.. Now I can start work on the job! Howard |
Ian Parkin | 09/04/2023 17:27:01 |
![]() 1174 forum posts 303 photos | Howard most of my dies that are 2” are not actually split but solid |
Clive Foster | 09/04/2023 17:44:18 |
3630 forum posts 128 photos | Howard You need a bit of oversize if the die is to easily go into the holder. I have one that is less than 5 thou oversize relative to the die diameters and it's a total pain to get dies in and out. Usual method is to screw a stud or similar into it to use as a handle. Its important to get the die seated true against the back of the recess which is hard without a touch of wiggle room. Clive |
Harry Wilkes | 09/04/2023 17:57:51 |
![]() 1613 forum posts 72 photos | some years back I need to cut a thread on site I had the 2" die but no die holder I managed using a jubilee clip with a screwdriver in the gap, yes bit 'sketchy' but done the job H |
bernard towers | 09/04/2023 18:30:08 |
1221 forum posts 161 photos | Best of luck with using a die that size for accurate sizing where you could crewcut it accurately with a lot less effort. |
Andrew Tinsley | 09/04/2023 18:39:40 |
1817 forum posts 2 photos | Bernard, Howard is doing what you suggest, if you read his initial post.. Andrew. |
DC31k | 09/04/2023 18:48:14 |
1186 forum posts 11 photos | Insulation tape or beer can could be used as a spacer between the OD of a die and the ID of its holder if the difference is excessive. Every (handled, not tailstock) holder I have has three screws in it, one to expand the die and the other two to limit its expansion. |
noel shelley | 09/04/2023 20:30:22 |
2308 forum posts 33 photos | Like DC3 mine have 3 screws so OD not really critical. If your at Heacham I can lend you one. Noel. |
