RUBBER - ideas to bounce off!
Machining difficult materials...
Andre ROUSSEAU15/03/2023 01:41:31
90 forum posts
https://youtu.be/ljKKqtmJ9xQ
Handy Tip: On the few occasions I've had to machine Rubber-type materials like Neoprene, etc as a matter of routine I cold-soak them in the freezer overnight which results in a markedly harder material less prone to tearing and excessive deformation when cutting. If machining operations are to be protracted then periodic 'resting' the workpiece back in the freezer is advised.
David George 115/03/2023 21:29:23
2110 forum posts
565 photos
You can use pipe freeze kit to spray on rubber to keep it solid.
David
