Sonic Escape | 05/03/2023 12:10:34 |
![]() 194 forum posts 5 photos | I found an old Romanian dial indicator and I want to see if it can be restored. Now it doesn't run smooth. But I have no idea how to open it. The bottom can't be removed. Anybody has any ideas? |
Mike Hurley | 05/03/2023 12:17:10 |
530 forum posts 89 photos | Does the front bezel screw onto the main body? Note the small semi cicular cutout in it that may be there for use by some kind of pin spanner across it? It doesn't look as if that is there as a zero-setting adjustment for the scale as it wouldn't seem very easy to use in normal operation. Edited By Mike Hurley on 05/03/2023 12:20:00 |
Sonic Escape | 05/03/2023 12:25:22 |
![]() 194 forum posts 5 photos | The bezel rotates. But it has no thread. I can pull it. But the needles stay in place, they don't come out together with the bezel and dial. If I remove the bezel + dial (they are connected together) then I think the needles will bend. |
Clive Foster | 05/03/2023 12:26:40 |
3630 forum posts 128 photos | Deleted Edited By Clive Foster on 05/03/2023 12:32:40 |
Michael Gilligan | 05/03/2023 12:48:54 |
![]() 23121 forum posts 1360 photos | Posted by Sonic Escape on 05/03/2023 12:10:34:
[…] The bottom can't be removed. […]
. Given that there is a joint-line visible in that photo ^^^ I find that very surprising MichaelG. |
Sonic Escape | 05/03/2023 12:54:03 |
![]() 194 forum posts 5 photos | Unfortunately that is not a joint line. It is just a chamfer. Unless it was not painted over. Here is a high res picture: |
Michael Gilligan | 05/03/2023 13:02:08 |
![]() 23121 forum posts 1360 photos | O.K. … thanks for the clarification Very weird … Mmm ! MichaelG. . Here’s an old Batty one for comparison Makes life a lot easier !! . I suppose there could possibly be neatly countersunk screws concealed under that Hammerite paint … a few seconds investigation with a magnet might be worthwhile. Edited By Michael Gilligan on 05/03/2023 13:11:30 |
SillyOldDuffer | 05/03/2023 13:13:35 |
10668 forum posts 2415 photos | Never take one apart, but probably a press-fit, like a watch back. Watches usually have a slot allowing a knife to lever the back off, but replacing it risks breaking the crystal unless a proper press is used. I'm not sure dial indicators are meant to come apart in a home workshop. Inexpensive ones are replaced when they stop working, and the expensive ones sent off to a specialist repairer, who presumably has the equipment, spares and knowledge needed to do a good job. Nothing wrong with having a go unless breaking the dial is a disaster. I see the Makita angle-grinder I bought yesterday was made in Romania. I don't think it's meant to be repaired after I wear it out. Dave |
Sonic Escape | 05/03/2023 14:14:12 |
![]() 194 forum posts 5 photos | The bezel + dial assembly can be lifted 1mm. Until it touches the needles. And it is pulled back by something elastic. There are no screws covered by paint. I scratched it everywhere.
old mart | 05/03/2023 14:15:33 |
4655 forum posts 304 photos | I would try a screwdriver between the stem and the bezel to see if it starts to move out. If it does, then turn it and lever again. These mechanisms are made to be dismantled, and since the back is one piece, you have to go in at the front. You still need to remove the hands before the dialcan be removed. For the dial, do not use any solvents, try water with a couple of drops of Fairy liquid and a soft tissue with great care. You can use solvents when the dial and pointers are removed, followed by some light oil. Edited By old mart on 05/03/2023 14:17:28 |
Hopper | 05/03/2023 14:22:28 |
![]() 7881 forum posts 397 photos | You might have to use a clockmaker's special tool (clock hand remover) to pull the needles off their spindles so you can then pull out the bezel and dial face. Maybe. Or if you look at that small half-round cut-out on the edge of the bezel and slowly rotate it around the full circle, you might see a tiny little screw revealed that you can undo and that allows the whole assembly to be lifted out together. Maybe. That half-round cutout must be there for some reason. Or is it there to engage with the outer bezel and allow you to rotate the dial? Edited By Hopper on 05/03/2023 14:24:23 |
peak4 | 05/03/2023 15:42:29 |
![]() 2207 forum posts 210 photos | As per Hopper's comment, you might need to remove the clock's fingers. Bill |
Michael Gilligan | 05/03/2023 21:09:51 |
![]() 23121 forum posts 1360 photos | Probably worth linking this for the benefit of future visitors to the thread: |
D.A.Godley | 05/03/2023 22:15:51 |
143 forum posts 41 photos | I am not sure if he still offers the service , but Bob Dixon , friend of YouTube’s Doubleboost , did an excellent job on a DTI for me . |
Hopper | 05/03/2023 23:04:38 |
![]() 7881 forum posts 397 photos | Nice trick there in the video to pull the hands off without the special tool, using two Q-tips and two screwdrivers. |
Sonic Escape | 06/03/2023 18:39:55 |
![]() 194 forum posts 5 photos | The picture is not so clear but that half round cut on the bezel is actually a dent. Yesterday I decided to try to remove the needles with a tweezer. But before I poured a few drops of WD-40 in the center of the dial. The liquid went inside without having a change to dissolve the markings. I pulled the needles with moderate force but nothing happened. But then I noticed that the indicator works much better. The movement very is smooth. But sometimes it get stuck completely.
Swarf, Mostly! | 06/03/2023 18:49:45 |
753 forum posts 80 photos | Posted by D.A.Godley on 05/03/2023 22:15:51:
I am not sure if he still offers the service , but Bob Dixon , friend of YouTube’s Doubleboost , did an excellent job on a DTI for me . Ditto for me. Best regards, Swarf, Mostly! |
Mike Poole | 06/03/2023 20:50:15 |
![]() 3676 forum posts 82 photos | WD40 tends to dry and go sticky with time so the improvement may not be permanent, it does seem to lead to answer being a clean and lube with a suitable lubricant is what is required to restore your dial gauge. Mike |
old mart | 06/03/2023 21:29:13 |
4655 forum posts 304 photos | You give up too easily, two screwdrivers with fine ends would have the pointers off in seconds. Lever together resting on the bezel. There are three, starting with the red cap, then whichever is second down and then the one nearest to the dial. They will have a tendency to go into orbit unless a bit of tissue is resting on top as they are removed |
Grindstone Cowboy | 06/03/2023 21:48:48 |
1160 forum posts 73 photos | I'd hazard a guess at the stickiness being on the plunger, rather than the internal mechanism. A bit of petrol or lighter fluid on the plunger whilst working it up and down may solve your problem. Rob |
