1940s engine ?
Donald Williamson | 28/02/2023 15:27:01 |
21 forum posts | Petter av 1 diesel engine dated around 1940s. I am in the process of restoring the above and have a problem assembling the injector pump, can anyone help me with an exploded drawing of the pump? Yous Donald
Edited By Donald Williamson on 28/02/2023 15:30:36 |
Ady1 | 28/02/2023 16:00:17 |
![]() 6137 forum posts 893 photos | Can't find much in my stuff, found a reseller https://www.agrimanuals.com/petter-engine-manuals-135-c.asp Edited By Ady1 on 28/02/2023 16:01:09 |
noel shelley | 28/02/2023 16:57:06 |
2308 forum posts 33 photos | If it's like the LISTER eg a bryce I may have a owners handbook. I will see what I have. Noel. |
John Hinkley | 28/02/2023 20:40:44 |
![]() 1545 forum posts 484 photos | Donald, I know the square root of diddly squat about Petter engines but have a look at page 26 of the manual here: It purports to cover AV series engines. The picture show an exploded view of the injector. John
Edited By John Hinkley on 28/02/2023 20:43:50 |
Howard Lewis | 28/02/2023 21:02:20 |
7227 forum posts 21 photos | If you have taken the injector pump apart, EVERYTHING has to be spotless ly clean. You are talking lapped fit for the plunger and barrel. The position of the "gear" quadrant bthat fits around the barrel controls the fuel delivery, and should really be set by a specialist. Gettingb it wrong can occupy a lot of time and risk damage to the engine before the correct setting is reached. SAlso shimmkjing between the cam follower and the barrel is important. Take great care! Howard
John Hinkley | 28/02/2023 21:59:02 |
![]() 1545 forum posts 484 photos | Donald, Sorry, I got the page reference wrong. It should read page 62, figure 3.10 John |
not done it yet | 01/03/2023 07:47:06 |
7517 forum posts 20 photos | Searching images for jerk injection pumps is likely to show at least a similar pump. Re Howards comment on cleanliness - it is recommended to rebuild while immersed in clean fuel, to minimise any risk of introducing ‘scratchy’ particles during this process. I expect fuel delivery is varied by shimming, to alter the pump stroke? Or was that timing? It’s ten years, or more since I took a Bryce pump apart. The usual problem, with these pumps, is the non-return valve on the delivery outlet to the pump. |
Donald Williamson | 07/03/2023 08:38:56 |
21 forum posts | Hi friends managed to re build the pump it now runs fine. thanks Donald |
